SDS100/SDS200: SDS100 stopped receiving
tvengr
Well Known Member
Baltimore County, MD
I am beginning to believe that the RF amp may be blown. Even if the antenna connection to the circuit board is broken, the capacitive coupling and the components and foils on the circuit board should pick up enough RF to give a low RSSI reading. Did you key up a 2-way in close proximity to the scanner?
SA_tx_88116
Rather listen than stream
Cibolo, Texas
I do have a Cb radio and some 2 ways but I never key them up around the radio
ahodak65
Just wanted to see if you ended up sending it in to Uniden? Mine had the same issue, not receiving anything. I finally determined it to be the internal connector between the two boards, both had bad solder joints. I fixed it after I did the soldering work myself, which I would not recommend unless you know what you are doing.
I might end up offering to do the repair for others, which would be cheaper than sending it in to Uniden, so let me know if you still need it fixed.
SA_tx_88116
Cibolo, Texas
I sent it to get fixed about 3 weeks ago they said the RF board had been damaged which was weird because I’ve never exposed my radio to transmitters at a close range but we did have some strong storms that rolled through but anyways I got it back in a week and it’s fine now and thanks for your offer.
acadin
I just repaired my SDS100’s poorly soldered joints today, I also used liquid solder, a needle point solder tip , and a 20x stereo microscope. Yeah, do not attempt this if it’s your first time. Mine had 5 tabs with cracked solder.
