SDS200 And 100
Ubbe
Stockholm, Sweden
When I read the customer reviews on Amazon it seems that high endurance cards sometimes fail sooner than "normal" cards. I have the original SD card in my Homepatrol-1 and have more or less 5 hours use every day with replay recording enabled for almost 10 years now. The dashcam in my car use the same standard 32GB SD card that gets full two times a week since 5 years back. The only SD card or USB memory that have failed for me where the one included in a Whistler scanner that where faulty from first time power up and cannot be reformatted.
/Ubbe
iMONITOR
Silent Key
S.E. Michigan
/Ubbe
I drank the Kool Aid and bought a Samsung PRO Endurance 32gb Micro SD card for the 436HP. 32gb is far bigger than you could ever possibly need, but that was the smallest they make. But I think some of us have been a little mislead as to what we gain buying the "Endurance" cards. The more I read it's not about how many reads and writes they can do. It's about how they stand up to abuse, temperature, shock, humidity, etc. I think all Micro SD cards are very robust in that regard, in fact almost indestructible! They also tend to be capable of faster reads/writes. I don't think that's a big factor either. Scanners do not read and write at fast speeds. Someone else mentioned recently that the larger cards tend to boot up slower in scanners.
The most important performance/reliability factor IMHO is the card's edge contacts. If you can even find them buy one that has real gold plated contacts. They would be optimium for being corosion resistant, preventing any electrical resistance or intermittent contact. The slightest interruption in the connection to the scanner would cause failure. It's probably a good idea to occasionally remove the card and buff the edge contacts with a cloth or a pencil eraser and give them a wipe of electrical contact cleaner. That and the act of removing and reinserting the card will also help the card to wipe the contacts in the socket and give them a better contact/conductance.
Hit_Factor
Saint Joseph, MI
From what I recall in my 436 and sds100s they came with class 4 cards and no other marking except for 8gb. I replaced them with class 10 cards and the do indeed boot faster, receive the master db updates faster, and load the full db faster.
The larger could have been slower, but that's an incomplete spec, it wasn't slow due to its size, sdcards don't work that way. It could have been class 4 ( not sure that's even for sale these days) or maybe the card had a corrupt file system.
Ubbe
Stockholm, Sweden
I don't know if Uniden checks the integrity of the partitioned part of the SD card but Whistler do. And it's a huge difference in boot time if it's a 2GB partition or a full 32GB on a 32GB SD card in a Whistler. But that seems to be the result of a very slow data link between remote head and scanner as both USB and SD card speed are ridicously slow.
/Ubbe
Hit_Factor
Saint Joseph, MI
/Ubbe
This is a sds100/200 thread, none of this is relevant.
Ubbe
Stockholm, Sweden
Is it true that the higher the GB card the longer it takes to load in the radio ?
Larger cards do make the radio take a little bit longer time to boot up
I just wanted to explain why it could take longer to boot a bigger card in a SDS100/200 as any SD card handler in any type of device needs to read the filesystem and check how much free memory there is and other parameters.
/Ubbe
KK4JUG
GA
/Ubbe
4GB vs. 32GB: How much time are we talking about?
N9JIG
Sheriff
Moderator
Far NW Valley
Not long, a matter of up to 15 seconds or so on startup, perhaps less. While I haven't ever measured the time, it seems like forever when watching the radio but in actuality it is not long.
iMONITOR
Silent Key
S.E. Michigan
It would be nice if Sentinel could omit Canada's portion of the database from loading every time the scanner is turned on. Not a big deal, but I run four scanners and it is an unnecessary annoyance.
Hit_Factor
Saint Joseph, MI
You can go into the Canadian portion and avoid them in Sentinel. Living in Michigan, I get close enough frequently.
73, K8HIT
Icom: IC-7300, IC-PW1, ID-5100A, ID-51A Plus 2, IC-R30, Hytera PD782G, Kenwood TH-D74, Uniden SDS100, DVMega, SDRplay RSPduo
