SDS200 and proscan problem
kb3nun
west pittston
Running a sds 200 with a new laptop and getting error code and droping connection
the source is running on port 8500
the web server is running on port 443
and the remote server is running on port 5000
below is a copy of the erros I am getting
Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException (0x80004005): No such host is known
at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
at System.Net.Sockets.TcpClient.EndConnect(IAsyncResult asyncResult)
at SourceClient.ConnectToServer(Object State) in \ProScan\SourceClient.vb:line 132
Error Code 10 - The operation is not allowed on non-connected sockets.
Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it [::ffff:174.127.114.11]:808
at SourceClient.ConnectToServer(Object State) in \ProScan\SourceClient.vb:line 130
I have also had my ISP to my home and monitored for any problems and no drop offs in signal
ProScan
Software Provider
Ontario, Calif.
Did a complete uninstall of proscan 20.4 and even cleaned the registry of all proscann files
Now i installed the radio feed 6.0 and no problems
so what is the difference with them
No difference. The Source Client code is the same. Windows is producing that error. It seems the problem is intermittent so I would monitor RadioFeed over a longer period of time and then try ProScan again. No one else has reported that error.
{edit} ProScan and RadioFeed can be installed and running at the same time so I'm not sure why ProScan was uninstalled.
{edit2} If the problem comes up again then try this: At the command prompt, enter
nslookup audio1.broadcastity.com
kb3nun
west pittston
i wanted to delete everything in the registry to make sure that nothing was corrupt
and i will try your advise with the command prompt
kb3nun
west pittston
i mean something may have got corrupt when i installed proscan the first time, even knowing that i uninstalled it, but i didnt do the registry delete, so maybe deleting all the registry file may have helped, what is your opion on that
ProScan
Software Provider
Ontario, Calif.
What Registry entries are you refereeing to? Hopefully you didn't mess something else up. I never advise to edit the Registry.
ProScan
Software Provider
Ontario, Calif.
i went to the registry edit and did a find of procsan and deleted everything that came up with that name
If you see anything with ProScan in the registry, it's because Windows is remembering the recent apps used or a shortcut added.
Don't focus on the Registry.
ProScan
Software Provider
Ontario, Calif.
Also if it happens again,
Verify the error is the same which is: System.Net.Sockets.SocketException (0x80004005): No such host is known
Perhaps google search -> troubleshoot dns server
This link may be helpful.
kb3nun
west pittston
sorry it has taken me so long to reply did alot of testing, I am still having. Issues here is what I am deal with
Proscan software
Source only running. No issues ,no errors
Source and web server. Running. No issues no errors
Source, web server ,and remote scanner over ip and that is were all the errors start
The errors come up on the source screen , no host found and the non connected sockets and all the other errors
But when i turn off the remote scanner over ip all errors stop
ProScan
Software Provider
Ontario, Calif.
Proscan software
Thanks for the testing. Several moths ago, in version 19.10, the RSOIP was changed to accept IPv6 addresses. It shouldn't cause this problem but anything is possible. If you send me a bug report then I will send you a test file using the RSOIP from ver. 19.9
Bug Reporting
If you discover a bug, send an email to support@proscan.org. The advantage of email is so I can ask questions and send you production quality files with additional testing to help fix the bug. The person reporting the bug will get the fix sooner than waiting for the next release. Put "bug" in the Subject line.
Bug Reports - Advise on the following:
  • Product (ProScan, Free Client, or RadioFeed):
  • Version:
  • Scanner type:
  • Scanner firmware version (if applicable):
  • OS type:
  • Options pertaining to the bug:
  • Describe in detail what the bug is doing or not doing:
kb3nun
west pittston
Bug Reporting
  • Version:
  • Scanner type:
  • OS type:
were do i get the bug report at
