SDS200 Brand NEW With Display Issue
JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
See the Picture. The SDS200 on the Right is BRAND NEW and just cloned from the one on the Left.
Display Colors SAY Identical in Sentinel but they are obviously NOT.
Any ideas anybody? How about Joe Bearcat?
Jim
werinshades
Chicago , IL
Not a display issue as you titled this, you used a different profile on Sentinel to clone it would appear. Read from scanner with the one on the left, make sure you save it, then Write to scanner to the other one. No issue, nothing to worry about.
mr10pt
Lowell, IN
Was just going to mention I had similar issues. I did not change the SD card, but ejected and reinserted the card. That solved my problem.
ProScan
Software Provider
Ontario, Calif.
To prove (to the vendor) that it is a scanner problem. On both scanners, go into the Menu - Display Options - Customize - Set... then hit the E key then Set Text Color. See if both scanners look different.
JimD56
Hey Bob Thanks for chiming in. Yes the NEW SDS200 display is reduced in quality on the set color screen.
Specifically, the colors are run together and are not as crisp and separated as the old SDS200.
However, I just tweaked the colors and changed to a Red, Dark Orange, and Gold configuration, from a Dark Orange, Orange, and Gold config and now they match.
palmerjrusa
Frederick
Be interested in seeing side by side comparison of the scanners' set text colors displays.
JimD56
Look at the 2 Screen Pictures. They are labeled OLD and NEW. Specifically, look at the Gray, Yellow, and Green in the last row on both pics. Also, look at the CYAN, DARK BLUE, and BROWN in the second row. On the New SDS200, the color looks like CYAN, BLUE, and RED.
palmerjrusa
Frederick
I'd put his down to variation in the SDS200's screen components.
I recently bought another BCD436 (my other unit was purchased shortly after this model came on the market). The LED color values are markedly different.
werinshades
Chicago , IL
Also, the receive sensitivity is definitely better than the older one when side by side same antenna. So, I'm keeping it and will deal with it. (y)
So if I understand this, you're unable to change the display via Sentinel, but it's working when you do this manually or is it just a contrast issue? I correct this in Sentinel under: Profile...Edit Profile..Display Opions...Dimmers (Lower Right Corner, and set them to 10%/40%/100%. Scanner defaults to a lower value when new.
As far as not being able to make display changes via Sentinel, are you using the supplied cable or an off market brand? If the display is not functioning as it should, and still able to return for another, might be better off going that route. Shouldn't have to go through all this with a brand new scanner.
JimD56
I have no problem changing colors and profiles and the USB cable that came with the SDS works just fine.
It is definitely a screen color LED variation which I am willing to live with. I'm keeping it. Very happy with receiving sensitivity.
