I got my SDS200 yesterday and I'm pretty impressed with it.
Pros:
It fired right up without any issues. And immediately began scanning local systems. I'm guessing when the DMR upgrade was put in they put my zip code in.
It's a heavy little brick, and I like that. The mobile bracket is solid and works great as a tilt stand. It's not going anywhere.
The display is very nice.
It seems to receive pretty decently. Less stuff needs to be avoided at work than my other scanners require. Work is a huge RFI mess with PCs and LAN cables everywhere, so just a few avoids is pretty impressive. My GRE PSR500 sitting in the same spot needs about 30 frequencies locked out to be able to scan. Its like 6 with the SDS200, and they are mostly VHF and UHF medical freqs. At home, it needed 3, two are the same as two that have to be avoided at work, and one is on a rail frequency that every scanner has to have locked out/Avoided. Nothing local here anyway on that channel.
Analog audio is very clear and loud.
The AC adapter is very cool running compared to most of the others I've had. Unit itself is barely warm after
If I put my ear right up against it, I can hear some sort of slight buzzing, but it's hardly there and not a problem at all. Sounds like when you take a radio and tune in a PC's CPU, but at a very low level.
Cons:
The LAN being on the front is a huge boner. A right angle plug is a help, but I don't understand why it's not on the back.
Digital audio, at least most I've heard so far sounds very "flat", with the exception of a local Connect+ system that sounds really potent and actually "real" compared to P25 and all the other DMR I've heard so far. I have a ton of external speakers and maybe one of the ones with a hotter high end can help out the digital audio response.
I kind of wish it was just a little bit bigger, just for the ergonomics. One with say an inch bigger screen in both dimensions and a larger keypad would be awesome. But it would cost a lot more.
Now I need to start my favorite lists and get it down to my core setup.
