ProScan: SDS200 multiple remote listeners on ProScan?
CellMasterK
Paramus, NJ
Hi Folks,
I can't find a straight answer on this- Can multiple users in the same home network listen to the same SDS200 simultaneously with ProScan? I want to share my feed to multiple computers in the house.
Thanks,
Mike :)
fxdscon
¯\_(ツ)_/¯
Hi Folks,
Thanks,
Mike :)
Yes. Whether you are using Proscan's web server or RSOIP you can set the number of allowed remote connections very easily:
fxdscon
¯\_(ツ)_/¯
THANK YOU! I saw one thread that seemed to indicate not and that's my sole reason for considering that scanner.
Any of the Uniden scanners that are supported by the Proscan web server can be accessed by multiple connections. Multiple users can be connected through your home network, and at the same time (with the proper port forwarding setup in your router), outside users can also connect from anywhere that has internet service. With different levels of password protection, any of those users can listen to, view, and control the scanner remotely. Proscan is a great program!
Compatible scanners listed here:
CellMasterK
Paramus, NJ
Thanks, that's very helpful. It appears I can try it on my SDS100 first. I'll download it when I have time to play. (y)
