ProScan SDS200 scanning over network
N1GTL
CT
I am trying to get the SDS200 working over the network with proScan (locally). My scanner IP number is set but when I try to connect with ProScan, it keeps timing out. Assuming the default port is 5000? I can ping the scanner but I cannot seem to get to access it. What am I missing?
ProScan
Software Provider
Ontario, Calif.
The scanner to ProScan communications doesn't have anything to do with Web Server and RSOIP features.
Go to the Comm. Port menu and select URL. Click the URL Setup box then click the Auto Detect IP Scanners. Does your scanner show in the list?
N1GTL
CT
Go to the Comm. Port menu and select URL. Click the URL Setup box then click the Auto Detect IP Scanners. Does your scanner show in the list.
OK, I can bring it up locally but I'm not getting audio.
EDIT: I found some audio settings I am working on now. Thanks!
N1GTL
CT
I found the settings and it's working. I cannot believe I am just discovering the capabilities of the scanner and software. Is there a Android version so I can access the SDS200 from my phone but WITHOUT the scanner being connected to a local PC?
eaf1956
Evansville, IN
We Wish lol (after rereading, I meant a android version of Proscan or even the client version)
