Also, more than likely the replacement will either have or develop the problem even, if the part is in it since the display board ground plane is not properly grounded by design.
If the hum was the main issue I'd open it and check for the part, but the popping doesn't seem to be a common issue here. Based on serial numbers it is likely it was installed at the factory. Also, since I am claiming defective due to the popping it will be free to ship back.You can get the part for free, and installing it doesn't void the warranty. Probably less inconvenient than being without a scanner during the exchange, and less shipping cost.
I will do the Static Discharge fix on the replacement if there is objectionable hum. Having done a search, I just don't see people having a problem with the internal speaker popping. I'd think with all the complaints of hum, if the popping was part of the hum issue, more people would have mentioned it.Also, more than likely the replacement will either have or develop the problem even, if the part is in it since the display board ground plane is not properly grounded by design.
I will certainly do that. It appears you are the only one here who has experienced the same issue so I know you are curious.Definitely reply back to this thread if the replacement has the pop.
I too have a problem with a popping noise at the beginning and end of a transmission but only when using ear buds at night.
No popping noise from the internal speaker.
One of these will solve that.I too have a problem with a popping noise at the beginning and end of a transmission but only when using ear buds at night.
Edit: Further info on the pop
The pop occurs every time a key beep occurs and also every time I turn the audio from off to on (0 to 1). If a TG has back and forth conversation without going back into scan in the meantime, the pop does not occur each time a transmission occurs. The pop is clearly in the audio circuitry. It isn't something gone wrong, it's an artifact of the design of the unit.
I just tried mine and it is the same, although I only get it when turn the volume from 0 to 1 or 1 to 0 while a transmission is going on. I also get it with the volume turned down to 0 when a transmission starts and stops.
If it is an artifact of the design, why aren't more people hearing it?
According to Jon, in this case they won't help.I do not quite understand how those in line isolators will help,
Nope. Mine has no pops or any other audio artifacts.I am hypothesizing that every SDS200 does it out of the box. That's why I am asking for videos of people who claim their scanner is NOT doing it.
Can you post a video to Youtube of your unit receiving multiple transmissions (analog and P25 if possible) at a low volume (1-5) in a quiet room? I would like to confirm that the pop truly isn't there.Nope. Mine has no pops or any other audio artifacts.
I can do better than that, I can post recordings made in ProScan. I've got scanners to mod, so I'll post the audio later.
I've seen plenty of people indicate they hear the noise in headphone audio, and I've heard the noise in YouTube videos recording scanner audio straight from the scanner, so I don't think that's the case. My SDS200 doesn't have any hum, CPU RFI, or popping, so I can't test to confirm or refute that either way. What you hear in the recordings I posted is the same as what came out of the speaker, minus the room background noise.But haven't people that have had the hum say it doesn't appear on recordings or in ProScan? Maybe the same with the popping?
