Sentinel SDS200 priority channel confusion
NightOwl326
To turn on priority channels for conventional / trunking what does one turn on, set at, click on its
very confusing.
CT
its
very confusing.
It's complicated...
priority scanning
ofd8001
Louisville, KY
I answered a similar post for you in another thread, which was for trunked system priority.
For conventional systems, you also mark the desired channel as P-Ch in Sentinel as you would for trunked. But, for conventional, you have to edit the applicable profile, go to the Miscellaneous Tab and select a Priority Scan Mode (either Do Not Disturb or Priority).
NightOwl326
Thanks for the help! This thing has a steep learning curve but its a blast and an assume scanner.
