HP-1: Sentinel work for both?
worble7
Fremont, Ca
does sentinel work for both home patrols 1 & 2 ?
is the scanner mount the same?
Thanks jeff
torontokris
Toronto Canada
be sure to update to the latest Sentinal to get the HP-2 compatibility
Version 2.03.02 adds support for the HomePatrol-2
hiegtx
Mentor
Dallas, TX
Thanks jeff
The Sentinel program used for the HP-1 was updated and now supports both the Home Patrol-1 & Home Patrol-2.
If you have both, as I do, you may want to flag any Favorites lists that include P-25 Phase II systems; those systems can only be monitored on the HP-1. However, all other Favorites lists (those without P25 Phase II systems) can be used on either scanner, interchangeably.
Clarify what you're asking about the 'scanner mount'. The two models are the same size, so a windshield or vent mount kit for the HP-1 would also work for the HP-2, if that's what you mean. The USB cable is the same as well.
fxdscon
¯\_(ツ)_/¯
I think you meant to say HP-2 there?
worble7
Fremont, Ca
thanks that helps I have the 1 and my brother is thinking of getting the 2 so I will be the lucky one to load the files. thanks again
