BCD436HP/BCD536HP: Setting Avoids
scnrfrq
Erie, PA
When setting avoids on the scanner, are they temporary until you use Sentinel for an update? Then they are replaced by what's on your Sentinel profile?
Ubbe
Stockholm, Sweden
Push once on the avoid button and they are temporary and will be cleared when you turn off the scanner or reload that list. Push twice on the avoid button and it will be stored permanently to that list on the SD memory card. Every setting in the scanner will be overwritten by the settings done in Sentinel but it will warn you that the settings are different and you can choose to skip the overwrite of what is in the scanner.
/Ubbe
