Fizz306
Hello all!
Maybe you all can read my amazon review, along with my correspondence with Shireen regarding coax issues I'm having. Terrible and erratic SWR across the entire 70cm spectrum.
Of note is the sales rep for Shireen stating I should probably use RG-8 for UHF transmissions rather than their LMR-400 equivalent. Am I bonkers, or does this make no sense?
-----Original Message-----
From: Sales Team - Shireen Inc [mailto:sales@shireeninc.com]
Sent: Wednesday, January 07, 2015 1:50 PM
To: sales
Subject: Contact Form
E-mail: XXXXXXXXXXXXX
Telephone: XXXXXXXXXXXX
Comment: Good afternoon,
I purchased a 500 foot roll of your LMR-400 equivalent from an Amazon reseller (allrfcables). The cable performs well when transmitting from 1.8 MHz through 150 MHz. Unfortunately, the UHF ham bands (420 MHz - 450 MHz) presents concerning issues in regards to SWR.
This coax has been connected to an Arrow Antenna 2m-70cm J-Pole. I have tried replacing the original run of your coax (approx. 40 feet) with another length of your coax, only to find similar SWR issues. Using my Icom radio in the sense of a spectrum analyzer, the SWR would vary widely between 435-450 MHz, from a low of a good 1:1 ratio all the way up to 10:1 or higher. The high peaks of SWR varied between the two different pieces of Shireen coax. When replaced with a length of DX Engineering RG-8 coax for a quick test, the SWR maintained a level 1.1:1 across the whole 70cm band.
Normally I would just stick with this new coax, but at 70cm the losses on non-LMR-400 type coax are higher than I'm willing to accept. I've read nothing but good reviews regarding your coax, and fear that I've received a bad spool.
Please note that I have used a good portion of the roll already for 3 separate HF antennas and the J-Pole previously mentioned, and only noticed the 70cm SWR issues after deploying most of my antennas at home.
Please advise on what Shireen can do to remedy this situation.
Regards,
Rob
Dear Robert,
I read your email in detail.. Seems to me that you would need RG8 (with teflon dielectric and solid copper conductor) type cable, instead of LMR400 type.. Our RFC400 or LMR400 cable are made of foam dielectric and copper clad AL as center conductor.. We have been selling our RFC line of cables for more than ten yrs now and never got any complain due to cable quality..
On the other hand it is quite possible that there is impedence mismatch with the antenna that caused VSWR go off. Its hard to guess what caused this problem and how standard RG8 fixed it.. BTW DX engineering is also our customer so most likely you have use our cable too.
Now we can do which ever option you prefer..
1. Take the spool back from you and replace with the new one. Or
2. Issue credit for unused spool, if you prefer to return..
Either way you like, we want you to be 100% satisfied with the purchase.
XXXXXXXXXXXXXXXX
Rob XXXXXXXXXXXXXXX
2:36 PM (4 minutes ago)
to sales
XXXXXXX,
Thanks for the reply. I am puzzled why you suggest to utilize a more lossy cable like RG8 on UHF frequencies over an LMR-400 equivalent. Are you saying that because you're using foam rather than teflon, and copper clad aluminium center conductor is not suitable for UHF+ transmission?
I am also confused because I have used authentic Times Microwave LMR-240 and LMR-400 coax in the past for UHF applications without any issues. My contact at Arrow Antenna strongly believes that this is a coax issue, as he says "if the SWR is not 1.1:1 across the entire 70cm spectrum, the coax is not up to the task."
Side note - it's interesting that DX Engineering's coax is Shireen. I didn't know that at all. Makes me wonder why there is such a drastic difference per foot between DX Engineering and other sellers like allrfcables on Amazon.
Regardless, I'd like to replace the whole spool, as I will most likely replace all the coax for my HF and UHF antennas. How can I go about returning the remaining spool to you for replacement?
Again, I appreciate the prompt reply and assistance.
Regards,
Rob Fissel
Amazon Review:
Terrible SWR issues above 70cm/430 MHz, January 7, 2015
By Robert W Fissel
Verified Purchase(What's this?)
This review is from: 500ft spool 400 grade cable, RFC400 (Electronics)
I made this purchase after reading several reviews from sites like QRZ and eHam, where users had great success with this coax. Being nearly $.50 cheaper per foot than traditional Times Microwave LMR-400, I decided to take a chance.
This cable appears to perform well on everything below 70cm (430 MHz). After installing multiple HF antennas, and one Arrow Antenna VHF/UHF J-Pole, using up 2/3rds of the spool in the process, I noticed that the SWR on 70cm was erratic and unacceptable, and would vary widely from 1.1:1 up to 10+:1 throughout the 70cm band. Everything below 70cm, when properly matched, showed acceptable SWR. My MFJ antenna analyzer also shows acceptable/expected line loss from 2m down through the HF spectrum.
I cut another length from the same spool, thinking that maybe my PL-259 connectors were bad or maybe it was just a bad run to begin with. Still the same erratic SWR across 70cm. I can only imagine what SWR would be like on higher frequencies. I tried a separate radio with an SWR meter to confirm my IC-7100 wasn't the culprit. Again, the SWR was all over the place across a band with an antenna that should present 1.1:1 across all 20 MHz of spectrum.
I went on to rule everything out in the transmission line from feed point to radio. Used a different lightening arrestor, bypassed my SWR/watt meter, used different coax from arrestor to radio...everything. Still no improvement, the issue here is definitely with the coax.
It's worth noting that I did a quick test with some DX Engineering RG-8 coax, and the antenna showed a solid 1.1:1 across the whole 70cm band.
While the coax performs well on HF, I purchased an LMR-400 equivalent to minimize losses on UHF+ frequencies, in addition to providing superior performance on HF. This has been disappointing to say the least. I hope it's just a bad spool and that either allrfcables (the Amazon reseller whom I purchased through) or Shireen will be able to remedy the situation.
I've contacted Shireen through their website and will advised what type of customer service they provide, and/or if allrfcables reaches out to me with a solution.
To: sales
Regards,
Rob
Dear Robert,
XXXXXXXXXXXXXXXX
Rob XXXXXXXXXXXXXXX
to sales
XXXXXXX,
Regards,
Rob Fissel
Amazon Review:
By Robert W Fissel
