After reading all the posts, there are a few things that haven't come to the surface on
discussing the differences between the SIMULCAST and regular multi site trunking.
First, there is the issue of the 3 db capture range of a signal strength. If one signal
is stronger than a second signal by 3 db on the same frequency, the stronger signal
will win and capture the receiver. Doesn't matter if it is SIMULCAST or regular
trunking. If you get into the non capture zone between two transmitters, on a regular
trunking system or a non SIMULCAST system, you may or may not be able to hear
a usable signal.
When a SIMULCAST system is used, all the transmitters are on the exact same frequency
and the audio sent over each transmitter is delayed by some fixed number of a fraction
of a second. Normally this is set up for the most distant transmitter with no delay and as
you get closer to the origination point of the audio, more delay is put into the audio path.
you need to have a fixed audio path to make this work. renting T1 circuits from the phone
company won't hack it as they have a tendency to change circuits around as they do
service work on the circuits. When they change a circuit routing, this causes the delay
to change and messes up the audio delay the system was set up with.
Another problem with SIMULCAST, is that there is a limit in the max distance that can
be adjusted for between the transmitter sites. This again has to do with the delays that
are added into the audio path so the transmitters will function correctly. If the delay
gets beyond the critical point, the receivers in the field will not be able to decode the
digital signal.
A normal SMARTZONE trunking system is cheaper to install, cheaper to maintain and
doesn't have the timing issues to contend with like a SIMULCAST system. There are
2 reasons to use a SIMULCAST system. The first is a lack of channels. The second
is so the vendor can make more money. Your much better off to go with a normal
SMARTZONE trunking system. The equipment is lower in cost, the radios in the field
play much better with it, you don't need a tech on the road all the time, it will cover a
greater distance in miles between the sites, and I think in the end it sounds much
clearer.
I am sure that my comments will bring the rath of the sales teams out in force. It
may also stir up a number of system managers, but the bottom line, unless there
is no other option, stay away from SIMULCAST. It will only cause problem in the
long run. Plus your forced into installing your own microwave system to carry
all the radio system traffic. This tends to swell the cost of a system in a big
hurry. Remember we are talking Public Safety systems here so your going to
need a hot standby microwave radio system. A complete loop is the best way,
but not always doable. Last time I looked, a 6 GHz, hot standby, with antenna,
waveguide, installation, license and a tower heavy enough would run you in
the order of $100 k per end of each microwave path. If you have just 3 paths
to make a loop from 3 locations, (don't forget this includes the dispatch) that is
only 2 remote tower sites, your talking about $600 K just to get it off the ground.
Jim
Hi Guys,
I noticed alot of the new systems are switching to P25 Simulcast systems, and this creates issues for people who may want to monitor the system. I am guessing that this is because the transmiters are overlapping. It has been pointed out in many threads that the only way of solving this problem is to point a directional antenna a one of the transmitters.
My question is this: How are the Motorola radios configured so that this not an issue for them? Can these settings be duplicated on the GRE? Perhaps a firmware udate would allow for these changes to be made???
Thanks,
Joe
