Simulcasts?
trentbob
Silent Key W3BUX
Bucks County, PA
Bob, I think that antenna is the Austin Condor! I have one and honestly it was not worth it’s weight.
That's it Herb, good memory, never did a thing for me but the marketing was so good I kept trying it LOL! Thanks hahaha.
jonwienke
More Info Coming Soon!
VA
Another option would be to put the antenna in a coffee can and use the can as a director of sorts and point it at one tower.
That's bad advice for conventional scanners, and completely useless and unnecessary for SDS models. All that will do is attenuate the signal, it won't make a directional antenna.
joeyperillo
Adrift in an analog world
Yardley, PA
trentbob - so sorry to be off the air last night - brutal day working in the sun, another about to start! Some answers to your questions and some other info about my muddy SDS 200......the radio has no rubber feet nor do I see any in the packaging, I don't have the mounting bracket on - when I have the radio on I have it elevated on the desk so I can see the display and also so the speaker is not flush with the table - it can breathe.....I have also used it with a high quality Altec portable speaker....no appreciable difference.....I have not moved it around the room but today I am going to take it with me in the car - that ought to show it some different terrain! I am now using a 6" coiled rubber antenna that I dug up from a cobwebbed analog dustbin in the basement......(was probably for a BC200XLT) - signal strength is excellent. I will also switch to the stock stick which as you say, un-extended is a quarter wave antenna......hitting the bricks soon, will report - thanks again for your help
whooey
Gainesville, FL
This video helped me tremendously, manual threshold of 7 and my before garbling 536HP scanner runs like a champ.
trentbob
Silent Key W3BUX
Bucks County, PA
Yep no doubt about it going to manual threshold 7 can help in Bucks County for 536. Although the o p started with the 536 he has upgraded to an SDS 200 which of course would not use threshold level secondary to the SDR chip. :)
joeyperillo
Yardley, PA
Wish I had seen this before I returned my 536 for simulcast distortion - do you think this monkeying about might help my SDS 200 which is unfortunately still muddy? I have a couple worthy gentlemen helping me with other suggestions as well........can't hurt to try, yes? Thanks for this. Stay safe.
trentbob
Silent Key W3BUX
Bucks County, PA
Okay Joey I know exactly what antenna you are talking about as I owned that radio. Performance on 700 will not be optimal with that antenna but it should work. Again, your best bet is the telescopic antenna and no, going to a manual threshold of 7 was not the answer for you not to upgrade to the SDS.
trentbob
Silent Key W3BUX
Bucks County, PA
You cannot adjust the threshold level on the 200 as it is an SDR Radio. See how you do today. Again that rubber duck is not an optimal antenna but the telescopic antenna is. Good luck talk later.
maus92
Eastern Shore
The Bucks County system was designed for portable in building coverage, thus will have a very strong signal indoors. No gain antenna required - the stock antenna is more than sufficient for receiving this system. I hope to be in the Doylestown area tomorrow, and hopefully I can make a sidetrip to Yardley. It is possible that the OP is getting some interference from a nearby cell tower; hard to tell. The Bucks County system co-locates on a number of towers that host cellular providers (we really need better receivers in all our devices moving forward.)
maus92
Eastern Shore
I've noticed during preplanning tomorrow's trip that the Bucks County system listing in RRDB needs some cleaning up / editing. As far as FCC licensing goes, only 12 frequency pairs are currently used in the TRS, yet the database shows 26. The extra frequency pairs - now unlicensed - were to have been used in the original system design that used two simulcast cells: north and south (or A and B.) That design was changed to a single simulcast cell before the system went live. I hope to verify what freqs are actually in use tomorrow, and I'll submit the changes subsequently unless someone else can verify the data.
Also, can somebody verify the 700 direct channels in the RRDB? They are essentially 700 interop channels, mapped thusly:
7TAC21EMS North769.00625
7TAC22EMS South769.01875
7FIRE21Fire Police769.03125
7FIRE22North Fire769.04375
Natl ItinerantEast Fire769.05625
Natl ItinerantSouth Fire769.06875
7MED21Central Fire774.93125
7MED22Police 1774.94375
7LAW21Police 2774.95625
7LAW22Police 3774.96875
7TAC23Police 4774.98125
Natl INT774.99375
I would think that the EMS channels would be assigned to 7MED21 and 7MED22, and the police channels assigned to 7LAWxx or 7TACxx.
trentbob
Silent Key W3BUX
Bucks County, PA
Natl INT774.99375
I got a little busy today but I am going to check out the database this morning as it was updated yesterday. As far as the Simplex direct channels go I really only see them used by the fire department.
The database seems to be pretty good. The Ops talk groups that has one talk group assigned to each Zone and are permanently encrypted are there even though they don't need to use them anymore because they are set up to go encrypted anytime they want on the dispatch channels now as long as they return to the clear when they are through with the sensitive information.
Last week's database update did include all of the new talk groups in the 60s and 70s that dealt with EMS notification to specific hospitals. There are also some new talk groups with regard to Emergency Management that were not in the database last week. I'll take a look at the database in a while... honestly, I am not an Insider when it comes to the changes in the system, I depend on the kindness of a few very knowledgeable people here in the Pennsylvania forum.
Thanks for your input!
joeyperillo
Yardley, PA
... yes Herb... That would be a terrific way to desensitize the antenna and isolate one tower. At this point that could be part of the detective work involved here but should not be necessary with a SDS 200 secondary to its having a SDR chip... I'm kind of stumped on this one and it's certainly part of the equation that I'd like to try... Joey could certainly be in one of those weird crazy spots that still exist in the system, they're not common but they're there. I hope you'll follow the discussion and keep chiming in, I appreciate that with your experience and familiarity with the SDS... do you remember this antenna? It's from the early 80s... A really long thick rubber duck, very soft and floppy. It was geared towards VHF high and UHF. Definitely deaf on 700 megahertz. It was touted as being like a super antenna. Don't remember the name but I still have mine LOL.
maus92... I go through the Newtown bypass area, over to Yardley and then down Route 32 on the river into Morrisville a couple of times a month as my daughter lives there... I've never had any issue with the SDS 100 or the apx 7000 in the car... If you are able to sniff around that area, hopefully, Joey will give us a more accurate position of where he is...he really might be in one of those weird spots and I asked him to move the radio around in his house... I noticed when I first got the 200 that there was a spot in my kitchen where it just did not work and I was worried I had a lemon as my 100 and apx were right next to it without issue. Moved it around and found out it was right on par with the 100.
So Joey when you finally get online there are a few things we need to know, I'd like to know what your RSSI readings are? Specifically, you mentioned that your problem is muffled unclear Transmissions. If you have good reception secondary to your RSSI reading my big question would be... Do you have the radio sitting on a table without the mounting bracket or the four rubber feet installed? Is the speaker on the bottom of the radio flat against a table? Let us know if you installed the 4 little rubber feet on the radio or mounted it on the mobile mounting bracket inverted so it is a desktop stand?
trentbob - re SDS 200 better than x36 but not great - sorry for the sporadic responses when you are doing so much to help me - I think I mentioned, working Census in the brutal heat all day, every day - while the money lasts......so.....took the SDS 200 around with me all day in the car so as to introduce it to different environments. There are still times when cars (seldom dispatchers) are muffled or seemingly maybe over modulated but generally good.....perhaps digital will never sound as uniformly clean as the old days? More: I used just the stock telescope stick collapsed to 6 or 7" - the quarter wave you indicated....it is amazing the reception sitting in the car with no external antenna (not trying to reach Philadelphia or anything - that's for much later).....signal strength is excellent.....you had spoken previously about filtering, effecting delays or some arcane magic you know......you had asked me to download from Sentinel all of Bucks County and we'd cherry pick from there....I mentioned the county was loaded by Bearcat Warehouse per my request (and $). The names of the two directories on the card they put there are:
183145-Bucks PA and 183145-Regional
Is that six digit number what you're referring to when you ask what number my Favorites is/are?
You had mentioned from this list I should create individual favorites with specific filters....I think......
BTW, I think the radio sounded better in the car than where it was on the desk but the shortened stock antenna you suggested made a difference.....will I ever get consistently clean transmissions from this simulcast system? If so I suspect you are the magician I need........grazie......
trentbob
Silent Key W3BUX
Bucks County, PA
Yep, well a Magician I'm not... honestly, I have never encountered a situation where the radio wasn't loud, clear, crisp and dependable in a mobile or fixed application and I own two sds200s and one sds100 so something is definitely wrong here. If you're getting a good signal and reception is good then altering filters is not going to change actual modulation or clarity.
Your part of the county is well covered and should work well with the stock antenna sitting on your car seat, but it sounds like you're just not satisfied with the results you're getting.
Difficulties with the 536 are understandable, there are parts of the county where a non SDR radio will work with muffled inconsistent performance... but the sds100 + 200 have been stellar throughout the county and tests up against Motorola subscriber radios, other than the lack of volume punch, have been very good.
Without having the radio in my hands and fiddling with it and actually watching and listening to the results that you're getting I don't know what else to say other than... It's a very expensive radio and if you're not satisfied and something is definitely wrong for you... you should certainly take advantage of the return policy and get your money back.
Having a 536 again with all the gimmicks and attempts to make it work are not the answer either.
My daughter lives in the Newtown area near the National Cemetery and the SDS radios work great there, I also travel through Yardley and down Route 32 along the river into Morrisville and the SDS radios always work well there also, they keep right up with my Motorola gear.
Don't know what else to say, take advantage of the return policy and get your money back.
maus92
Eastern Shore
I was hoping that tvengr would read this thread and make a simple Sentinel file for the county for the op. I would not trust a vendor-produced file: it may have a lot of junk in it. These radios are sophisticated devices and require a bit of knowledge and experience to configure properly. It is interesting that the op says the radio performed better when moving to another location outside his home, which suggests some localized interference. Let's see if he tests using the stock antenna at home also improves reception.
I will report back on my findings from my excursion to Doylestown today. I'm bringing along a cch logger, an SDS 200 and a Unication G5 to baseline the system.
trentbob
Silent Key W3BUX
Bucks County, PA
Actually this has been quite a protracted project because the o p has been very busy with work, Jim was on the thread on Sunday night but may not have wanted to step on any toes at that point, his help would be welcome as I really don't know where to go from here without getting a lot more information from the poster and have them take the time to fiddle with the radio at my direction. We never really did that. Of course that's what it would take. Poster has not really been available at night and works all day.
I have never seen a radio that was programmed by the vendor before, I would imagine they just take the system from Sentinel. I just don't know, it's something none of us would ever pay for.
The problem here does not seem to be signal and I got the impression the signal was strong, the complaint is muffled or unclear transmissions which is not a characteristic of the 200 or the system.
I look forward to your results today. Maybe I will drop a PM to Jim and see if he will come back and maybe help Joey out.
maus92
Eastern Shore
I'm curious what the op considers "muffled" audio or unclear transmissions. There is a lot of variation in audio quality caused by how the user interacts with the equipment, specifically speaker mics. Also, P25 audio can sound "muffled" to those who are more used to analog radio.
joeyperillo
Yardley, PA
You guys are great and I appreciate you so very much - trentbob - I don't really want to send this back and have nothing especially if it is just my ignorance of the beast that is the problem - I would gladly compensate you were you of a mind to having me drop it off to you and having you analyze and or "fix" it.....my email: joey@joeyperillo.com - lemme know! (thanks for your understanding of my heavy work schedule - it all goes to "zero" on September 30).....
trentbob
Silent Key W3BUX
Bucks County, PA
Interesting, very good points, I agree.
joeyperillo
Yardley, PA
maybe that's the answer - it's the nature of the P25 system that I will occasionally get "muffled" (I liken it to "over modulated") messages, mostly from road units but sometimes from dispatch......
trentbob
Silent Key W3BUX
Bucks County, PA
I personally never would charge anyone for something like that, it's fun, I have certainly done it before.
On September 1st I'm moving to a new house in Bristol borough. I'm keeping my place for a few months before it will be sold. I'm going to be doing a lot of repair work, painting and such to the new house so unfortunately I won't be that available.
Anything is Possible. I just wanted to make sure that your radio was not overtly defective and that you would miss the 30-day return window the warehouse provides. If you're available we can talk about it some more but it would take time on your part to work on the radio so we may have to wait a bit.
I will definitely be back on tonight.
