SIRN
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
According to the minutes, the Lost City site should be online
I took a trip to the Lost City site, today... Was actually able to see the tower (coordinates helped--many thanks, Mike). Our veterinarian is located in this area, and it's always seemed to be a radio dead zone for SIRN. Here's what I found:
1. The site is strong on the west side of the ridge, but almost non-existent to the north and east--probably by design, since the Wardensville site handles that area.
2. In spite of the site's strong signal, the new Lost City site doesn't appear to be passing any traffic. Several scanners in my vehicle were able to copy sporadic / weak signals from both the Moorefield and the Wardensville sites, but nothing came across the Lost City site. Also, my G3--which is always rock solid--locked onto a new RFSS/Site 1/56, which is the site info for the new Lost City site, but never passed any traffic. I realize this could be an affiliation thing... I'd have to spend more time in the area to be certain.
3. Site freqs
4. Site info
5. Affiliation Log
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
3. Site freqs
4. Site info
5. Affiliation Log
Excellent Mark! Thank you so much for doing that. You've got all I need to add that site to the DB.
even though most sites have at least six freqs, as you said there was no activity -- and it's possible you could wait there for days to see any voice traffic to determine any additional frequencies. And heck, it may only be a four-freq site anyway. It's probably never going to be a high volume site and likely to only be used as fill-in.
I'll get this one added to the DB.
Again, I appreciate your efforts!
Mike
lebrunmn
@lebrunmn Mark, Just curious -- were you able to see the actual tower up on the hill anywhere? I think it was "only" supposed to be a 180 ft tower.
Yes... was actually able to see it quite well from the road in the area around the Teets Cattle Company on WV Rt. 259. It's on the ridge almost directly across from this farm's driveway. That ridge is probably 1500 to 1800 feet up from the road.
I'll make certain to provide an update when we take our precious pup to the vet later this fall.
mtindor
FMP24 PRO USER
Thanks, I appreciate the info. As I'm sure you could guess, I have zero familiarity with that area. DIdn't know if the tower would be visible from your vantage point or not.
Mike
lebrunmn
Happy to help.
Just to clarify, I was looking at the topo map, and realized that I didn't take into account the elevation of the main road, which is close to 1400', so the tower is only 400 or 500 feet above the road.
mtindor
FMP24 PRO USER
Happy to help.
Got it. I love looking at the roads leading up to some of these SIRN sites. Some of them clearly would require 4wd vehicles and likely be a nightmare to get to in the winter!
BM82557
Berkeley Co WV
Just a quick question, I am curious as to why TG 8853 is in the DB as WVU Air Following when I hear the med helos call it Air Track?
mtindor
FMP24 PRO USER
I personally don't have any idea. What do you consider "Air Track" to be? Sounds like "Air following" I guess. But I have no idea who submitted that so I'm not sure.
Radar412
split between Berkeley Springs, WV & Wyoming
This excerpt from WV SIRN protocols should explain some of the is terminology. I'll try to post a link to the document so you can read it. It's only 4 pages and has a map also.
" Medical Air Ship Flight Tracking and Communications a. The West Virginia Office of EMS has established three of the medical command dispatch centers as medical air ship flight tracking centers. These locations are Huntington MedComm, Charleston MedBase, and WVU MedComm. i. Each of these three dispatch centers are responsible for aircraft communications from any medial provider while over West Virginia air space. ii. Three primary flight tracking trunked talkgroups have been established along with one over-flow alternate. These talkgroups are only to be programmed into airborne subscriber units, consoles, and control radios at dispatch centers for flight tracking. No other use is permitted or appropriate. iii. Each of the three flight track centers will have one primary trunked talkgroup and all three command centers will have access to the over-flow alternate. iv. The established trunked talkgroups for this purpose are: 1. 8851 – MED CHAS AIRTRAK 2. 8853 – MED WVU AIRTRAK 3. 8855 – MED HNT AIRTRAK 4. 8857 -- MED ALT AIRTRAK "
Radar412
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Sounds like it was named by someone with aviation experience but not the document that gave its official names. Flight following generically means the same thing except it's done via ATC and not by a state tracking center. If these are the proper names though I'm for making the change.
iceman977th
Mess with the Bull. Get the Horns.
Catlettsburg, KY
Passed this on to mtindor already.. but wanted to post here. Got my ingest server put up at our tower in Catlettsburg to test, and it looks like SIRN is using mixed P25 P1 and P2 on the Cabell Co sites. Milton has also changed CC's. No changes on the Wayne Co sites. I'm going to add more sites to it and see just how far I can reach, and see what other fixes need done, UHF is singing up there.. awaiting a couple of changes before I start feeding to Calls.
BM82557
Berkeley Co WV
I posted this about TG 9994 several years ago and promptly forgot about --
Anyone been able to id TG 9994, it is active infrequently on the Martinsburg/Berkeley County SIRN site --
; NOT IN DB (TDMA)
P25, BEE00.170, 9994, 90033, 50, Normal, 15, 2020/09/25 10:30, ""
P25, BEE00.170, 9994, 110070, 50, Normal, 4, 2023/04/13 10:30, ""
P25, BEE00.170, 9994, 1300011, 50, Normal, 11, 2023/04/13 10:25, ""
P25, BEE00.170, 9994, 1300025, 50, Normal, 10, 2023/04/13 10:23, ""
P25, BEE00.170, 9994, 1300026, 50, Normal, 9, 2023/04/13 10:30, ""
I've been following it again . I'm not not sure it is DHHR as an answer to my post in 2023 indicated. Mostly it sounds like techs working on equipment. Yesterday they were talking about Juniper switches -- Network Switches | HPE Juniper Networking US
Here is the info on the radios I've logged --
P25, BEE00.170, 9994, 550, 50, Normal, 9, 2025/05/13 17:52, "", "DEM APX N70 P1", 9EB7115E
P25, BEE00.170, 9994, 575, 50, Normal, 2, 2025/08/06 14:47, "", "DEM VM8K JAG", DA125B80
P25, BEE00.170, 9994, 90034, 50, Normal, 137, 2025/07/15 10:42, "", "EMD 108M4 GIAN", B225F2B6
P25, BEE00.170, 9994, 90060, 50, Normal, 149, 2025/01/28 15:23, "", "WVEMD 108M3 GI", F92D9162
P25, BEE00.170, 9994, 991113, 50, Normal, 92, 2025/07/15 15:21, "", "EMD 100M2 MCCO", 2E85A311
P25, BEE00.170, 9994, 991137, 50, Normal, 80, 2025/05/13 7:04, "", "EMD 108M2 GIAN", A6720D29
P25, BEE00.170, 9994, 1300006, 50, Normal, 1, 2023/09/11 14:17, ""
P25, BEE00.170, 9994, 1300009, 50, Normal, 0, 2025/10/11 23:01, "", "MSI TEST 4", 68D1358A
P25, BEE00.170, 9994, 1300010, 50, Normal, 34, 2025/09/09 10:40, ""
P25, BEE00.170, 9994, 1300011, 50, Normal, 19, 2023/04/13 13:09, ""
P25, BEE00.170, 9994, 1300025, 50, Normal, 23, 2023/04/13 13:09, ""
P25, BEE00.170, 9994, 1300026, 50, Normal, 11, 2024/04/30 11:20, "", "THWP46 NEXT-1", 788695B2
P25, BEE00.170, 9994, 1300027, 50, Normal, 27, 2025/07/30 7:42, "", "THWP46 85K-1", DF35D17E
P25, BEE00.170, 9994, 1300028, 50, Normal, 41, 2025/10/11 9:42, "", "THWP46 85K-2", B5396FBD
P25, BEE00.170, 9994, 1300030, 50, Normal, 90, 2025/01/30 15:32, "", "VBNJ87 NEXT-2", 8C315073
P25, BEE00.170, 9994, 1300033, 50, Normal, 27, 2025/05/13 17:51, "", "VBNJ87 85K-2", A60721BD
P25, BEE00.170, 9994, 1300040, 50, Normal, 1, 2025/10/20 12:12, "", "MDWX36 NEXT", 5829DE51
P25, BEE00.170, 9994, 1300060, 50, Normal, 56, 2025/10/14 15:01, "", "WTGX38 85K", A56FFEFC
P25, BEE00.170, 9994, 1300062, 50, Normal, 37, 2025/08/27 16:27, "", "WTGX38 NEXT", 9C062BE3
P25, BEE00.170, 9994, 1300085, 50, Normal, 0, 2025/10/20 18:38, "", "MSI THWP46 B-1", 93FB5D05
Anyone identified the users?
WV8EJW
; NOT IN DB (TDMA)
It is Motorola System Tech talkgroup
N4TX
West Virginia
Very general question here and I'd appreciate help especially from this forum. I'm near the Hardy/Hampshire county line and want to buy a new scanner that would primarily be used for SIRN and maybe a few old VHF frequencies if they are still in use in any neighboring counties. (I doubt that.) My Pro-106 is an antique now but works fine. However the Starrsoft program and my settings are lost and I need to add some new TGs, especially for the new tower that Hardy has begun using a mile from and LOS to my QTH. I also listen to MilAir and would probably add some favorite frequencies there, too.
I think that the Pro-106 should be honorably retired and I should shop for a new scanner. I'll be looking for a handheld and don't mind manually entering TGs, freqs, etc.
Computerwise, I'm on Macs for home and business but I have an old Dell that I can use for a few legacy ham radio operations. I don't mind doing my own research before buying but I figured that you guys would probably have some solid advice. N4TX@icloud.com or direct here. Thanks very much. All suggestions welcome.
n8jsw
Ohio
If in your budget get the uniden sds-100 as it works great with SIRN and simulcast if you have towers that have it down that way. If no need for simulcast then the bcd396p2 is a good way to go and both scanners can use pros can which is easy to use
N4TX
West Virginia
Thanks. Looks like the SDS-100 can do absolutely anything I might encounter. I see the price, so I guess all that versitility does cost. Appreciate your advice as I get back into things.
