Sentinel: Sites missing from Sentinel, but appearing on Web?
Mikek
I am looking at this system: Mobile Relay Associates SoCal NEXEDGE Digital Network Trunking System, Multiple, California
This is a multi-county system with 30+ sites listed when viewing the URL above, however, not all sites appear in Sentinel. For example, only about 18 sites show up when viewing the system under "California-Orange" or "California-Los Angeles", and only a handful of those listed appear under "California-Riverside". Sites do NOT appear to be grouped by their geography (LA-area sites in the LA County section) and there are several sites that do not appear anywhere in Sentinel, Sierra Peak for example. (yes, HPDB has been refreshed and shows "current") .
There are a ton of multi-county, multi-site systems that do not have this issue. Any idea why this one is different, and how I can get the complete inventory of sites in Sentinel, and eventually, to the scanner?
Please move this to a more appropriate forum if the answer isn't DB related! Thanks!
mwjones
Van Alstyne, TX
Looking at that system, and looking at another NexEdge system I'm familiar with that uses dynamic addressing, it appears that Uniden's import from the RRDB API doesn't like LCN's above 1023 and thus will not import into the Sentinel DB (but with dynamic addressing, leaving the LCN as 0 works as intended, since the frequency is sent OTA in the control channel messages)
By comparing the system I've contributed to, the system as a whole doesn't appear in Sentinel since all the frequencies have been populated with the correct Channel Assignments.
Looking at Mobile Relay's system, and using the Hollywood site for example, in RRDB it shows the following:
CH IDFrequency
22874471.47125
0471.48125
22875471.49375
0472.250
34360507.375
345520507.875
34664508.325c
34752508.600
34848508.900
But if I look at Sentinel, I only see:
Again, this aligns with the issue with the Channel ID being higher that what Sentinel supports.
This would be a Uniden problem, but I'm not sure if @JoeBearcat is aware of it (Joe, if you're reading this, the Baylor Scott & White Health system in the DFW area doesn't appear to import into Sentinel at all for the same reason, and I helped to populate it out so you and your team have something close by to troubleshoot with but it's likely something as simple as "if system type = NXDN and LCN > 1023, import but set LCN = 0")
Mikek
Ah - that seems 100% logical. Thank you! And I'll ping @JoeBearcat again just to let him know my fingers are crossed for a fix!
Mikek
@JoeBearcat Just pinging you again to see if there's an update on this? Would be REALLY helpful to have fixed. Thank you!
Mikek
Alternatively - is there a way to manually edit the LCN's before they're uploaded?
JoeBearcat
Uniden Representative
Not sure I saw this one. I will check into it along with another dB issue I'm waiting on info for.
trentbob
W3BUX- Bucks County, PA
That's good, and appreciated, can not the ones that you are waiting to hear from, allow you to keep up with the weekly database updates?
Probably would eliminate any problems. Don't know your internal management structure but.. just asking.
Mikek
@JoeBearcat Any update on this? This issue is limiting usability of the platform, and seems to have an easy fix (per mwjones, above) - can we get a fix?? :) Thanks!
donc13
Grand Junction, CO
Not having anything to do with the RR DB, Uniden'S program to select the data, "massage" it into a usable format for Uniden scanners but having been a large system. s administrator, DBA and program development manager for close to 30 years.. I can tell you that no change is "easy"
it takes analysis of the issue, available staff of programmers, QC testing folks, checking if scanner firmware needs update and doing that and so forth.
So.. be patient, it can take quite a while to create what you think should be a quickie.
