Hello,
I noticed that both the National Mall and Udvar-Hazy Center have Passport LTR systems. I suspect another Smithsonian site having a Passport LTR system is the Paul E. Garber Preservation Facility in Silver Hill, Maryland (SE of Washington DC). I seem to remember hearing some LTR bursts on the 406 MHz band in the area when I was down in Washington last year.
It is likely that all the Smithsonian sites are linked together because that is one of main features of a Passport LTR system. The idle bursts on a Passport system tend to be every 2 seconds.
I also need a favor from someone in the area that can monitor the Smithsonian Passport LTR system and is familar with Trunker. This system is not on the standard 450 to 470 band. I need someone to use the ltrdump program found here
http://www.radioreference.com/modules.php?name=Forums&file=viewtopic&t=10074
and log the idle bursts on the system for 10 to 15 minutes. Email me the ltrdump.txt file.
Normally you would need a low-pass slicer for LTR work but a regular one should work for the idle bursts. I am trying to figure out if the frequency band information is sent in the idle bursts. This will help improve the LTRDump and LTRTrunk programs.
Thanks and 73 Eric
Thanks and 73 Eric
