Southern California Edison
bcorbin
Los Angeles
Site 100 shows:
935.325cc
935.875
936.325
936.850a
NAC 5A8
Hmmm - ok, I don't see that in the DB. What am I missing?
I guess what I was trying to say is that I have 936.825 entered into my PSR-800 as Site 1-100, since that was the CC given for 1-100 on the adjacent-site broadcasts from 1-089, 1-101 and 1-107. The fact that I was seeing '1-100' flash on my display meant it was tracking a CC on 936.825 (as that is how it is programmed at the moment).
Now, there were a few complications -
* unlike earlier GRE's, the PSR-800 doesn't dump CC info to the screen - no site, no tower, no NAC
* I forgot to dump the CC to SDRAM
* 1-100 was actually the only adjacent site tagged as being down in the broadcasts
In short, I'm not at all convinced that the site I was listening to identified itself as 1-100, hence the request for someone to take a look 8*)
LAflyer
Global DB Admin
Moderator
SoCal
Its not in the Db yet as its not been worked yet. I was just checking those frequencies per your inquiry. I'll get the Db updated with site-100 shortly.
Heard voice traffic on TG 12065, 12177 and 13199 on site-100 during my short monitoring.
bcorbin
Los Angeles
Ah, ok. When you posted 'Site 100 shows:' the list didn't include a CC on 936.825, so I got it in my head that 1-100 must have been identified with another hilltop. No worries. Thanks for checking...
If the old TG map is still valid, those map to:
12065 (33040 - Ops 42, Santa Monica)
12177 (33232 - Ops 39, Ventura)
13199 (51184 - ???)
Fireboat03
Pepsima1 Duplicate Account
Banned
I was hearing 936.5875 in OC tonight. Sys ID of 05AAh-0198
Talkgroup 12567 and 12161 and 12627
inigo88
California DB Admin
San Diego, CA
Hey guys,
I've added Oak Peak (Site 1-120) and Breckenridge (Site 1-136) to the database.
I don't have a Phase II capable scanner yet, any recommendations?
The conversion equation jlanfn posted earlier works perfectly. Type II Talkgroup = (P25P2 TG - 10000)*16.
The resulting talkgroups I get using that equation are consistent with the type II talkgroups that used to be on those sites.
Code:
FileVersion:8
-TowerInfo
#This section is here for information only.  With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID             : 5AA
System Name           :
WACN                  : BEE00
Tower Number (Decimal): 1-120
Tower Number (Hex)    : T0178
Tower Description     :
Control Capabilities  : Data,Voice,Registration
Flavor                : Phase 2
Call Sign(s)          : WNVW897
Timestamp             : Sat Oct 17 19:03:40 2015
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,935.01250,0.01250,-39.00000,"Confirmed",0.01250,1
05,935.01250,0.01250,-39.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"04-0016","i",935.21250,"04-0016",896.21250,0,1
"04-0138","c",936.73750,"04-0138",897.73750,0,0
"04-0151","ad",936.90000,"04-0151",0.00000,1,0
"05-0032","v",935.21250/0,"05-0032",896.21250/0,0,8
"05-0033","v",935.21250/1,"05-0033",896.21250/1,1,9
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
189,"T0159",5aa,"04-0156",936.96250,""
1103,"T0167",5aa,"04-0146",936.83750,""
1107,"T016B",5aa,"04-0063",935.80000,""
1116,"T0174",5aa,"04-0038",935.48750,""
1117,"T0175",5aa,"04-0079",936.00000,""
1119,"T0177",5aa,"04-0032",935.41250,""
1135,"T0187",5aa,"04-0054",935.68750,""
Code:
FileVersion:8
-TowerInfo
System ID             : 5AA
System Name           :
WACN                  : BEE00
Tower Number (Decimal): 1-135
Tower Number (Hex)    : T0187
Tower Description     :
Flavor                : Phase 2
Call Sign(s)          :
Timestamp             : Sat Oct 17 19:09:30 2015
-Tables
-Frequencies
"04-0030","d",935.38750,"04-0030",896.38750,0,0
"04-0054","c",935.68750,"04-0054",896.68750,0,0
"04-0111","a",936.40000,"04-0111",897.40000,1,0
-Neighbors
1108,"T016C",5aa,"04-0052",935.66250,""
1120,"T0178",5aa,"04-0138",936.73750,""
1133,"T0185",5aa,"04-0032",935.41250,""
1134,"T0186",5aa,"04-0016",935.21250,""
LAflyer
Global DB Admin
Moderator
SoCal
I added site 106 to Db today also.
Now we really need to work on identifying locations of all the sites in LA region.
Also do we think its safe to copy/paste all talkgroups from the older system by applying the conversion?
While I think this might get us going, I would be very surprised if new TGs and some changes were also not introduced as part of the P25 system rollout.
inigo88
California DB Admin
San Diego, CA
I agree there might be new stuff, but by nature of the Motorola SmartX conversion process I think the old talkgroups must still exist on the new system since both are linked together in concurrent operation. So it's worth converting all the troublemen and substation categories for sure.
bcorbin
Los Angeles
I've already got that in spreadsheet form - I can upload it here this evening if it will save anyone some work. 8*)
LAflyer
Global DB Admin
Moderator
SoCal
Yes sure you can attach it in a forum post or otherwise PM it over. Thanks
I'll work to get the Db updated in the coming week.
bcorbin
Los Angeles
LAFlyer -
With regard to posting the old TG's under the new map, I think the potential advantages in using this as a starting point outweigh the risks. If someone notices that TGID #### doesn't match the description in the database, they're likely to submit a correction - the data will sort itself soon enough.
Wasn't something like that done for STRS for a while, where the map was ported over and something like 'tentative' was appended to the end of the description? Two downsides that I can think of - 1) if no one in the know ever checks in to say a tentative description is on the mark, that 'tentative' label will sit in the DB for a long time and 2) there's really no way to identify/weed out an old TG that isn't being used on the P25 system.
Ok - I dug out my spreadsheet. There's not much to it. The first column should be the P25 TG number, the second, the old TG number and the third, an abbreviated alpha tag.
Note that there is a duplicate TGID in the database (old:34768 new:12173), it is a duplicate in this file as well...
  • tg-sce.zip
bryan_herbert
Las Vegas, NV. DM26jc
Picked up a BCD436HP a few days ago and have been logging SCE P25II in 'Discovery' mode for about 12 hours now - I am NOT hearing the same protocol that was heard on the old analog system.
Repairs can still be heard on the Substation talkgroups. Status updates (ticket status, unit status) are done on the Operations talkgroups. I even heard a fair amount of traffic from one of their copters on TG 13581 'Air Ops' this morning. However, the FSR talkgroups are quiet - dispatching and outage announcements are now done by MDC.
I will do a dump of the Discovery logs later tonight or tomorrow morning and post what the radio collected, looks like there's 24 hits.
bryan_herbert
12065 | 33040 | 42 SANTA MONICA OPS
12069 | 33104 | 35 THOUSAND OAKS OPS
12077 | 33232 | 39 VENTURA OPS
12089 | 33424 | 36 ANTELOPE VALLEY OPS
12097 | 33552 | 50 BIG CREEK OPS
12113 | 33808 | 51 SAN JOAQUIN OPS
12127 | 34032 | 29 SANTA ANA OPS
12139 | 34224 | 33 HUNTINGTON BEACH OPS
12149 | 34384 | 26 COVINA OPS
12153 | 34448 | 27 MONROVIA OPS
12173 | 34768 | 32 DOMINGUEZ HILLS
12177 | 33232 | 39 VENTURA OPS
12539 | 40624 | CENTER SUB
12603 | 41648 | VINCENT SUB
12605 | 41680 | PARDEE SUB
12607 | 41712 | MOORPARK SUB
12609 | 41744 | SANTA CLARA SUB
12625 | 42000 | STATE STREET SUB
12627 | 42032 | LA FRESA SUB
12629 | 42064 | LA CIENEGA SUB
13011 | 48176 | SPC 'RED' UNIT-TO-UNIT
13301 | 52816 | ADMIN MESSAGES
13495 | 55920 | MATERIAL TRANSPORT OPS 2 (MTO2)
13581 | 57296 | AIR OPS
Not in the database...
12219 | 35504 | "YOU READY THERE BY THE AMMONIA TANK AND I'LL CYCLE THAT VALVE? ...ROGER THAT, JOE. I'M READY FOR THE CYCLE ON THAT AMMONIA TANK VALVE."
Fireboat03
Banned
noted 10 more new talkgroups tonight. I submitted them to the database
avascan522
Los Angeles County, CA
SoCal Edison P25 TRS
Has anyone heard any traffic on District 61: Catalina? If so, any relevant conversations - island related repairs, status updates, etc.?
bryan_herbert
Spoke too soon, Catalina TG 12173 is active right now with repairs being done in an unknown area. Don't know if related but I see on the outage map planned maintenance repairs being done in Torrance.
bryan_herbert
On TG 12173 (Catalina FSR) I'm hearing DOC sending a crew to Montebello. Don't know where or what for, all that is now sent to the crews over Skype.
bryan_herbert
Can't tell if the 436HP is more sensitive than the 396XT on 900MHz or if they're still building out the SCE P25II system, but here in Santa Clarita they definitely seem to be using their talkaround channels more.
