I have one, I just don't want to remove the scanner from where it's mounted to measure. In fact, I know what the impedance of the scanner is. The question is now if a 4 ohm speaker will work well with an 8 ohm output.
My Uniden SDS100 doesn't have any limitations from the earphone jack, it has plenty of power to drive a 2 ohm speaker. So no limiting resistors or it would just be a whisper from a low impedance speaker.Speaker impedances are variable with frequency...
Uniden handheld scanners have headphone jacks with an attenuated output to avoid overdriving headphones. They need amplified speakers to produce an acceptable volume.
My Yaesu FTM-400 specified its output impedance as 4-16 ohms. Power output into an 8 ohm speaker is 3 watts. With a 4 ohm speaker it is 8 watts. Neither will damage the radio. One will be louder.
Stop worrying and get a nice speaker. Maybe consider an amplified speaker with DSP.
You could look at the internal speaker if it doesn't say what ohms, you could check it with an ohm meter if you have one.![]()
Analog has a high pass filter of 250Hz to cut out the CTCSS/DCS subtones but isn't used in digital mode which then sounds to have more bass. That's not a bad idea to have a 100uF in series that will give a 8 ohm reactance at 200Hz, if it's a non polarised capacitor that can handle the alterating current. I wish that Uniden would give us the possibility to adjust those filters and levels to our own taste. They are now hidden in service mode and cannot be easily accessed.I have a 100mfd cross over capacitor in the old speaker to even out the analog and digital audio.
