St John Macomb
freqs
warren michigan
Does anyone know the mode the they are using .It shows 461.1500 fm mode but transmission is all digital sounded .
RayAir
Nothing digital indicated on their license, but you can search for "w2sjw radio sounds" and hear what the different digital modes sound like on an analog scanner.
I'd guess if they went digital it would most likely be DMR.
Compare what you hear to the samples on the above web site or post an audio sample of what you're hearing.
freqs
warren michigan
It's sounds DMR to me I just wanted to make sure before I upgrade my 436.my wife works there in the ER
RayAir
They're using DMR:
Color code: 1
TS:1
TG:1
Another DMR user I found in the area was on:
461.400
Color code: 14
TS: 1 TG: 10
TS: 2 TG:20
* Unsure who this is, freq licensed to Henry Ford Macomb Center, but on TG 10 they were talking about trucks coming
Anyway, with a DMR scanner or DMR radio you would be able to listen to St John Macomb Hospital. All clear voice.
RayAir
Yes, I decided I'd submit it.
It would be worthwhile to get the DMR upgrade as there's much to listen to in the area. NXDN, not so much.
freqs
warren michigan
Ok thanks the only reason I monitor them is that the wife is a nurse there. Ok iam doing the upgrade ive noticed a few freqs I want that have gone that route .
And iam a person that monitors everything from the Big 3 Police Fire DPW Dump Trucks to Drive thru's .
RayAir
No problem. The Comsource Connect Plus system is very busy and you should be able to listen to the downtown Detroit hospital police forces. They get a lot of interesting incidents.
