Starcom 21 Central IL
K9CRT
Decatur, IL
the past few days or weeks my scanners have went dead for the starcom channels for central IL like Decatur, Springfield, Champaign etc. State police dist 6-9-10 which have been working for years have now disappeared apparently they have moved to other frequencies. So my question for help can anyone here shed any light ??
K9CRT Doug Decatur, IL
BTW my scanners are Grecom & Radio Shack which work fine
rf_patriot200
Freeport, Illinois
Did your tower sites change ? Maybe try picking a alternate tower if there's one close to you?
K9CRT
Decatur, IL
ok I can do the posting but there is nothing wrong with my scanners but with the feed that is programmed and has been working for years.
Gradyo54
Monticello IL
I had a problem with my Radio Shack Pro 652 not picking up traffic a week ago. I could not get the tracking channel. I started turning off things in my home. I had a Verizon 4G cell phone extender interfering. Turned it off now my scanner is working. Your home network may be interfering. Just a sugestion.
scanman1958
St. Louis
You mention "Disticts" 6, 9 & 10. Remember, the districts have been replaced by troops. Along with that, many talkgroups have been moved around or switched. Are you getting any signal at all from any of the sites in your area?
K9CRT
Decatur, IL
No and its not anything in my home as was mentioned blocking another ham in my city scanner has went silent also. I even attached my outside antenna @60 ft and nothing. So I am thinking they must have moved there frequencies and was hopeful someone here in Decatur had the answer
timmer
Springfield, Il
I'm currently listening to talk group 13004, (troop 6), formerly listed as "Dispatch A" district 9. I'm located near Springfield using a GRE PSR 500 which I have used for years. Seems to be coming in clearly here.
Gradyo54
Monticello IL
Can you see if you are getting the Control channels? Are you getting any traffic on you scanner at all? I E other agencies NOT on StarCom?
K9CRT
Decatur, IL
I suspect I am not getting the control channels but for years both scanners were working perfect until a few weeks ago when both stopped on Starcom 21 IL state police along with another ham whistler scanner across town from me but yes getting other agencies along with ham repeaters and the weather ch. it has been years since I programmed it I was using Win 500 which I don’t have a download any more on my updated computer so on the Grecom and radio shack scanners what would folks recommend now going to ?
K9CRT
Decatur, IL
What software are you using to program I was using Win 500 I think it was but lost that with new computer so needing software for Grecom & RS
Bri112233445
Somewhere listening to KenCom
For starcom depends what you have available to you if you have a computer get a software defined radio dongle under $50 if you want the scanner uniden SDS series is the way to go.
Also @K9CRT did you see my post in the starcom thread. More than likely they switched to a new site which is why you're not picking up the old one The information for that is in that thread
Gradyo54
Monticello IL
I had problems with my RS Pro 652.
I bought the new software, got a premium RadioReference membership used it to populate my scanner with the latest Talkgroups and StarCom sites.
Cost me around 60 bucks. I used my old Radio Shack cable. These are very complicated scanners to manually program.
I got my software at Scanner Master.
Good Luck
K9CRT
Decatur, IL
Good Luck
You said “I bought the new software “ what software is this I have the programming cable
Gradyo54
Monticello IL
Mine is ARC Scanner Software ARC500 Basic.
Available as. a download or on a USB thumb drive.
I ordered mine from Scanner World. You have to specify the Make and model of your scanner.
K9CRT
Decatur, IL
Thank you
tvengr
Well Known Member
Baltimore County, MD
ARC500 Basic supports the GRE PSR-500, PSR-600, the Radio Shack PRO-106, PRO-197, PRO-651, PRO-652, and the Whistler WS1040, WS1065.
