Phil-Hogan
- Joined
- Feb 28, 2020
- Messages
- 8
I'm a novice and purchased a pair of Baofeng 888s to test prior to purchasing a few additional pairs. The intended use is to use them at a special event, with some people inside and other outside.
I programmed them to FRS/GMRS frequencies using the latest version of CHIRP (updated a few days ago)and using a Baofeng cable (I also tried programming them with the 888 software, which was easy but gave me horrible results).
Trying the various tone modes I have different results:
Tone mode has bad static when the radio is idle, but it goes away when transmitting
DTCS is clear when idle but the receiving radio receives a lot of static which makes hearing voice transmissions difficult.
TSQL is clear when idle but the receiving radio receives a lot of static which makes hearing voice transmissions difficult.
None has bad static when the radio is idle, but it goes away when transmitting
Cross mode has no static on idle, but the receiving radio doesn't receive transmissions.
The radios were tested within a building and from inside a building to outside. Distances were between 25 and 300 feet, and the results didn't vary in any qualitative way.
Channels were programed with and without privacy codes, in FM and NFM, High and Low power. Nothing seemed to make enough of a difference.
I'm wondering if the building's WiFi system is interfering, but I haven't had a chance to test them away from WiFi, and the environment we will use them in will have WiFi.
I know they are cheap radios (literally $10 each), so I'm not expecting the same quality as a $300 radio, but we need low budget radios for this application. I thought these would be better than the bubble pack Cobra CXT195 FRS radios we used previously; we need greater range capability, and hoped the real world 2W would be better than the .5W of the Cobras. The Cobras do not have the symptoms that these Baofengs do. I've already spent more time on these than I'd like.
Any help and guidance on getting these programmed and functional (reducing the static to tolerable levels) would be appreciated. Is there something in the other programming fields of CHIRP I should try?
Please don't lecture me on the legalities of these radios; I've done a lot of research, and know what I'm stepping in to. All users on GMRS will be properly licensed, and in FRS we'll stick to the 2W power limit frequencies.
Thank you for your replies.
