Dover E-6 detachment.. Noticed again E-6B 164388 RUPPE28 off Dover then offshore for work.
There must be a VQ-4 detachment there as you don't fly these old birds multiple times from same
base without some qualified ground support. Bussing them in from Pax River doesn't add up either.
Travis has long had VQ-3 detachment from Tinker but they long had their own section and hangar on base.
Thinking Dover must have a temp hangar area for the E-6B's. May become permanent addition in future?
BTW off Travis UNTIL28 E-6B 164388,Dover RUPPE28.. Rare coincidence in callsign numbers.
maus92
The OP
Thanks for the link. I don't know why Sevilla just doesn't have its own FIR, Politics probably ?
I never thought about the politics angle (I don't know much about their politics other than their are historical factions;) I thought it might be due to technology infrastructure / the ATC "concessionaire" ENAIRE, and their corporate structure.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Thanks to N1GAW in the military monitoring forum, I have captured the latest AP1A and B, along with the Eastern route charts, to my Google drive. The files are in a 13 MB zip file, and are found here (I hope I copied this right)...
Please see if you can download and unzip them (WinZip and the free 7 Zip should work fine). If so then I can put the link into the Delmarva wiki
Tanks...Mike
Tanks...Mike
Why not use my dropbox link I've had in the post for awhile.
mdmonitor
Guys,
Earlier this summer the local power company installed a new set of power lines about 50 yards behind my house. ever since then I've had lousy reception on my Bose Wave radio (in FM mode). Stations that used to be clear are now weak & scratchy.
So I did some research and on Amazon found the Monarch AM/FM?DAB indoor antenna. It was supposedly invented by a NASA engineer. It's a neat little thing. It's a ribbon antenna about 18 ins long and about 3 ins wide. It's covered in plastic and is very thin so it fits any space well.
I was curious and hooked it up to m y RS-2045 which I usually have hooked up to my disone up in this attic. It's designed to enhance FM radio reception and claims it has a 60 miles range. I was pleasantly surprised that the Monarch which is just laying on my desk is picking up VHF ATC aircraft traffic over 100 miles away and just as clear as my discone.
For anyone with limited space, especially in an apartment/townhouse this would make a great little antenna. Would be great for travelling, vacations etc. It has sticky tape attached so you could stick it on a wall or on a window. It comes with 15 ft of coax which has an F connector and a couple of adapters.
Best of all it only costs $20 on Amazon.
mdmonitor
1145- Hoser 11 flt (KC-10s # 63-8029 AE05AC & # 63-8040 AE0674) off WRI heading southwest. Working ZDC Pinion (133.975) then ZDC Montebello (121.675)
1148- Terra 96 (C-32 # 02-4452 AE0449 150th SOS NJ ANG) off WRI heading southwest. Working ZDC Linden (133.55).
KC4PSR
1208- Flight of 3 T6s just went over my house flying NE out of Hampton Roads executive airport in Chesapeake, VA. ADS-B shows only one, N1364J.
Registration shows this owner as SNJ-2 Corporation, i.e. the Geico skytypers. Must be returning home to Farmingdale, NY from yesterday's show in Ft. Lauderdale.
TerryPavlick
Wallingford PA Villas NJ
Using 123.425 air/air
mdmonitor
1420- ADS-B showing another MC-12 (# 12-00278 AE53FC) on the ground at Hagerstown. Ident showing as TEST5678
1428- Team 11 (KC-10 # 79-1949 AE01DE), just off the tip of southern NJ, working Brickyard CP (134.1) w/inbound msg.
1438- Axeman 1 flt (A-10Cs 104th FS MD ANG) working Dulles approach (254.25) cleared direct to Martin State. Coming back from working at the Evers MOA.
mdmonitor
jsoergel
Cincinnati/Dayton, OH
Here's the rest of the flight all the way into Minot. Picks up about an hour after the handoff from the previous recording. A little more eventful, WARBIRD 2 becomes a stealth bomber when its transponder apparently fails and then declares an emergency on the descent. At that point with ZMP only the ATC side could be heard and I couldn't quite make out what the problem was. Sounded like she read back "a small br..f.. (?) issue". At 5:05 on the recording.
WARBIRD 03 and WARBIRD 04 both did a low approach at KFFO, then direct to FWA. Assume they must have been the spares.
Chris52
Leonardtown, Maryland
Guys,
Could you please post the link to this ?
