Sticky Thread For Mid-Atlantic MilAir 2021
jetcrafter
Southern Maine
1725z 262.000 SW F-16s and HAF F-16 A-A chatter on inbound Coronet mission.
1725z 282.000 BLUE 62 and RETRO 11-14 flight Boom freq.
1730z 124.300 BLUE 62 flight switching to ZBW.
1730z 120.250 BLUE 62 flight check in with ZBW, in the block non-standard formation.
1740z 120.250 BLUE 62 wkg ZBW, flight will split up around EMJAY. BLUE 62 will be a single to KPSM and all four F-16s are going to destination KSSC.
1807z 133.425 BLUE 62 flight checking in with ZBW, block 260-280.
1822z 135.800 BLUE 62 flight check in with ZBW, in the block 260-280.
1836z 135.800 BLUE 62 wkg ZBW, MARSA terminated, flight splitting up.
1836z 292.150 RETRO 11 flight check in with ZBW.
That's all I have. Out of my range now. Hope you guys catch some comms!
mdmonitor
1348- Salty Dog 402 (prob F-18 VX-23) & unid acft worklng on PAX test discrete (235.875)
1354- Decoy 84 (C-17 # 00-0182 AE0818) working Mountaineer Ops (297.9) w/inbound msg.
1355- Hearing some ftrs chatting on 262.0. Maybe the Shaw F-16s?
1358- Unid acft (no call noted) working w/Echo Control (262.95).
1402- ????-11 (missed) working ZDC Salisbury (257.7) at FL260 non-standard formation 6 miles long front to back.
1408- Ftrs still going on 262.0 Strong at my location. Also a coupe of hits on 246.50 which I have as a Coronet freq.
1316- Hawk 01 (unid) working ZDC Hi (346.375) Requesting direct to Montgomery AL. AL ANG ????
1330- Bully flt (3 X F-16s 121st FS DC ANG) off ADW working ZDC Patuxent (281.4). Also on discrete (143.6)
Probably Mass ANG.. Have heard them before on road trips at high altitudes using HAWK callsign
mdmonitor
1415- Score 46 (MQ-4 # 168458 VX-20) working Giantkiller (238.1) at FL510 and confirming flt route back to PAX. Working VX-20 Ops (285.2) w/inbound mg.
1427- Wardog 1 flt (A-10Cs 104th FS MD ANG) working ZDC Blackstone (235.625) & on discrete (271.4) Poss going to Dare NC range?
jsoergel
Cincinnati/Dayton, OH
1242- Steeljaw working w/Score (VX-20) & Dragon (unid) on VX-20 test discrete (345.1) . Steeljaw queries Score if they "want to test the J voice link". Steeljaw advises Score & Dragon that he is sending tracks for targets in the Norfolk area. ADS-B showing Score 22 (E-2 # 162169 AE2FD6 VX-20) working in the Norfolk/ Oceana area at FL240. In the past the hex code AE2FD6 has been used by E-2D # 168076. so, not sure which acft is working today.
Interesting; STEELJAW used to be used by the E-2D test team with VX-1. Maybe they are also using it with VX-20 now? Could also just be a backend callsign these days
Are the test discrete freqs assigned to specific Pax squadrons? Or do they rotate between whichever one is most convenient?
freqhopping
SD201
They seem to use location based range freqs for operations but go to their squad ops freqs when in or outbound.
A little of both at times..
1500 local notice SCORE-13 167929 E-2D coming in from offshore on ADSBX. Maybe working carrier offshore.
1517 local DEVIL-11 flight of 2 back inbound towards A/C on 363.000>354.150 at FL12k down to 9k.
mdmonitor
Jared,
Not sure the test discrete are allocated. I think that some of them are allocated to a particular unit:
337.9 VX-1
339.625 VX-20
345.1 VX-20
365.7 VX-20
I'm guessing that the freqs used by specific units are allocated according to the mission/test flt
I think that here's a pool of freqs that are allocated to missions, test areas, range controls that are used by different acft.
Attached is a list of PAX freqs I got from Larry Van Horn several years ago. As you go through the list (at least for me) there are a couple of patterns that stand out.
  • PAX Freqs Larry 2014.txt
mdmonitor
1518- Unid working w/Echo Control (262.95).
1520- Devil-11 working ZDC Woodstown (363.0) & ZDC Kenton (354.15).
1523- Marlins (T-38s 71st FS) working in W386 (238.1) w/T-Bolt flt (F-22s 149th FS VA ANG) also on discretes (233.825/296.9/350,05)
1524- Score 77 (P-8 # 167951 AE222D VX-20) working w/Giantkiller (238.1).
1527- Score 13 working VX-20 Ops (285.2) w/inbound msg.
1535- Two stns, one L/C & other weaker, working P-25 comms on 141.55.
hill
Middle River, MD
Living near Martin State I always see the C-17 when it's parked there overnight, since it was there last evening. Never saw it takeoff, since it leaves when I am at work, but did see in the this morning after I was already in the work truck.
Just wondering where the ones that visithere are based, since it's way to far to see any markings on it. Does it come from Dover? Maybe it's ANG from Martinsburg, WV.
