Sticky Thread For MilAir 2016
A few visitors out to the Warning areas today..
MISTY 11-13 assume from Barksdale looking for entry into W-107 and W386 areas 1:18pm local.
Heard them departing UHF all the way couple hours later with ZDC 371.900 then 285.600
Update correction told they were B-2's from the 131 BW/110th BS at Whiteman.
Guess Reserve guys out for a weekend run.
Tech792
Central NJ
I had the MISTYs also but couldn't ID them. They must have been right off my coast because the signals were solid. I heard them mention Whiteman to the controllers.
freqhopping
Hearing some chatter on 267.0, a B-1 freq. Sounds like prep for AR.
1850- Sounds like whoever it is may be done.
1852- VOODOO flight RTB Langley ZDC 236.825
mdmonitor
Guys,
More pics from my Northrop friend. MD ArNG uh-72s (callsign Recon) at Delaware Coastal Airport (Georgetown DE)
mdmonitor
ACY- Atlantic City NJ (KACY)
ADW- Joint Base Andrews MD (KADW)
BW- Bay Watch-NAS PAX Area Advisory Control
BWI- Baltimore-Washington/Thurgood Marshall Airport (KBWI)
DAA- Davison AAF, Ft Belvoir VA (KDAA)
DCA- Reagan National Airport/CGAS Washington, Wash DC (KDCA)
DOV- Dover AFB DE (KDOV)
GK- Giantkiller (FACSFAC, Virginia Capes)
LFI- Joint Base Langley-Eustis, Va (KLFI)
MTN- Martin State Airport, Baltimore (KMTN)
NGTF-Northrop-Grumman Test Facility, Baltimore (KBWI)
NTPS-Naval Test Pilot School, PAX
PAX- NAS Patuxent River MD (KNHK)
PTC- Potomac Area TRACON
WRI- Joint Base McGuire-Dix-Lakehurst NJ (KWRI)
ZBW- Boston ARTCC
ZDC- Washington ARTCC
ZNY- New York ARTCC
1. VHF/UHF: ((Times are EDT))
((Reach/OSACOM/PAT/JOSA flts not included--Some acft idents from local ADS-B collectors))
0700- SAM 499 (C-20B # 86-0204 99th AS ADW)-depart ADW then ADS-B shows heading west. Returns to ADW at 1330.
0815- Marine 374 (UC-35D # 166374 MAW-4 ADW)-depart ADW then ADS-B shows heading west. Returns to ADW at 1150.
0900- Evac 0112 (KC-135T # 58-0112 PA ANG 171ARW Pittsburgh PA)-depart ADW.
1145- Colt flt (2 X A-10Cs 104th FS MD ANG MTN)-on discrete (271.4) working at Kiowa MOA Range.
1146- ADS-B shows Otis 35 (KC-130J # 167112 VMGR-252, MCAS Cherry Point, NC) over MD at FL190 heading north.
1149- ADS-B shows Trek 02 (C-130H # 90-1057 DE ANG 166AW/142AS Wilmington DE) in low level acty in vicinity of New Castle DE.
1152- ADS-B shows Steel 71 (KC-135R # 59-1490 147th ARS, PA ANG Pittsburgh PA) operating in W386/AR636 off MD/DE coast.
1154- ADS-B shows Royal 50 (C-17A # 01-0186 436th AMW/3rd AS DOV) in low level acty in vicnity of WRI.
1155- ADS-B shows Decoy 07 (C-17A # 01-0196 167th AS WVA ANG Martinsburg WVA) departing Martinsburg.
1157- Pacer 07 (C-21A # 84-0120 457th AS ADW)-w/BW (354.8) reporting completion pf maintenance test flt & requesting RTB ADW.
1227- Team 52 (KC-10A # 85-0028 305th AMW WRI)-w/GK (238.1) for clearance in to W386. Advises GK they are the tanker for the bomber.
1228- ADS-B shows Steel 64 (KC-135R # 58-0054 147th ARS, PA ANG Pittsburgh PA) over Philadelphia at FL300 heading west towards Pittsburgh.
1232- Hornet flt (F-22s 27th/94th FS LFI)-check into W386 (249.8) for work w/Dragnet (E-3D Tinker AFB OK). Also on discrete (389.1)
1234- ADS-B shows Jinx 61 (C-17A # 03-3119 305th AMW/6th AS WRI) in low level acty in vicnity of WRI.
1235- Omaha 5 (US Customs helo)-w/Phillips AAF (126.15) clearing out of restricted area. Also on discrete (136.375)
1236- ADS-B shows Arris 99 (KC-135R # 62-3541 22ARW McConnell AFB KS) operating in W386 off MD/DE coast. Arris 99 then moved into the PAX restricted areas and orbited there for most of the afternoon. Probably was working with the F-35Cs along with Score 59.
1237- DeeCee 51 (KC-135R # 62-3543 756th ARS ADW)-w/Liberator CP (351.2) reporting arrival back at ADW & will be doing patterns at ADW for next 1.5 hours.
1245- ADS-B shows Jumbo 70 (C-5M # 86-0025 436th AMW/9th AS DOV) in low level acty in vicnity of WRI.
1248- Weasel 51 flt (5 X F-16s 119th FS NJ ANG Atlantic City NJ)-w/ZDC Snow Hill (236.825) then check into W386 (238.1). Working w/unid tanker on W386 discrete (389.1)
1300- Bengal 41 flt (id as 2 X F-18Ds VMFA(AW)-224 MCAS BEAUFORT SC)-w/WRI Metro (239.8) for current winds in block Fl200-220. Also w/ZDC Casino (254.3). Also on discrete (234.8)
1303- Wolf 1 flt (F-22s 27th/94th FS LFI)-check out of W386 (238.1) & RTB LFI
1304- Scout 93 (F-22 27th/94th FS LFI)-check out of W386 (238.1)
1324- ADS-B shows Score 59 (KC-130T # 162310 (USMCR VMGR-234 JRB Ft Worth TX) working in PAX area. Unid tanker (no call noted---female pilot) working on PAX discrete (374.8) w/unid acft (prob F-35C CF-02) in AAR tests. Both acft awaiting arrival of F-35C CF-01.
1445- Venus 7 (C-32 # 09-0015 1st AS ADW)-depart ADW then ADS-B shows heading south. Returns to ADW at 1600 for some patterns prior to landing.
1448- Tester 22 (T-6B # 166042 NTPS PAX)-w/BW (270.8)
1455- ADS-B shows Royal 40 (C-17A # 06-6165 436th AMW/3rd AS DOV) departing WRI then heading south.
1505- ADS-B shows Opec 48 (KC-10A # 83-0082 305th AMW WRI) departing WRI then heading south.
1515- Tester 17 (T-38C # 157076 NTPS PAX)-w/BW (354.8)
1516- Tester 24 (T-6B # 166060 NTPS PAX)-w/BW (270.8)
1517- Raven flt (2 X A-10Cs 104th FS MD ANG MTN)-working at Kiowa MOA Range (233.454) & on discrete (271.4)
1519- ADS-B shows Duce 17 (KC-10A # 86-0037 305th AMW WRI) crossing MD just east of Wash DC at FL240 heading northeast apparently heading back to WRI. Also w/Brickyard CP (134.1) w/inbound msg & write-ups.
1520- Bison 41 (C-130H # 89-1187 328th AS AFRC, Niagara Falls IAP NY)-depart ADW then ADS-B shows heading northwest.
1550- Tester 18 (T-38C # 638315 NTPS PAX)-w/BW (355.8) clearing out of South Spin area and heading to Webster OLF.
1552- ADS-B shows Zeke 76 (C-32A # 00-9001 NJ ANG 108WG/150SOS WRI) approaching WRI from the west.
1553- Convoy 4492 (C-40A # 166695 VR-56 NAS Oceana VA)-w/NAS Oceana Ops (284.9) w/inbound msg.
2. HF: ((Times UTC, Freqs KHz))
15867.0 1400Z NMH3 (USCG TISCOM Arlington VA) USB/ALE sounding.
15867.0 1640Z R24499 (UH-60A #86-24499 Indiana ARNG Shelbyville Municipal Airport, Shelbyville IN) USB/ALE sounding.
15867.0 1800Z R23467 (UH-60A #80-23467 Indiana ARNG Shelbyville Municipal Airport, Shelbyville IN) USB/ALE sounding.
Ron (mdmonitor1@verizon.net)
Baltimore MD (390747N 763711W)
VHF/UHF: BC-895XLT/RS Pro-2045 w/Diamond D-130J discone (in attic)
HF: Icom R75 & Sangean ATS 909 w/45-ft PAR EF-SWL (in attic)
freqhopping
Pakistani Air Force-226 C130 passing over Loudoun, likely inbound to BWI. 133.85
1807- SCORE25 C-12 163838 inbound to Leesburg. Had been flying around the valley out west for a while after departing from Leesburg.
freqhopping
P-3 157325 NAVY AR325 departed KADW a little while ago, did some climbing loops to the east and then headed west. Leaving Loudoun now via AML. 118.675>133.55
Looks like it may have come into ADW from overseas yesterday.
freqhopping
Looks like DHS helos are heading from Manassas to Philly for the DNC.
N6974A, N6977A and N159CM
Rgr that, logged all 3 about same time thru here mode s 1545z-1600z
You may want to post them on the Penn DNC page.
Wonder if they will base out of Boeing? KPHL or Northeast Philly?
mdmonitor
You'll likely hear them on 165.2375 and 136.275
A couple of others:
136.375 (AM) DHS
136.525 (AM) Customs
123.025- Helo common
140.100 Atlantic City International Airport 119th FS NJ ANG (AM mode)
140.200 Atlantic City International Airport 119th FS NJ ANG (AM mode)
140.175 Atlantic City International Airport 119th FS NJ ANG (AM mode)
140.700 Atlantic City International Airport 119th FS NJ ANG (AM mode)
157.05 US Coast Guard
157.075 US Coast Guard channel 81A-US Coast Guard (FM Mode)
157.125 US Coast Guard channel 82A-US Coast Guard (FM Mode)
157.150 US Coast Guard channel 23A
282.425 US Customs Blue might be worth a shot.
Would also keep an ear on the Huntress freqs as well as the McGuire approach/departure/CP freqs. Would expect alot of CAP tanker track to be working on those freqs.
mdmonitor
Guys,
Philly CAP is up on 260.9.
Tanker is Taboo 01 (KC-10A from WRI) and fighters are ????-11 & 12. Can't quite catch the callsign yet.
Just heard the fighters clearer---callsign is Pitman-11 & 12 ( F-16CJ, 20 FW SHAW AFB SC)
Tanker is orbiting over I-95 between Philly & Trenton NJ.
