Tin,
I really like your new report format---adding the comments on the end of the log. But I bet it takes a ton of time & effort. Thanks though---in my opinion it really enhances the info.
One log puzzles me:
00-9001 ------- 01:04:53.665 C-32B 227th SOF / NJ-ANG (Fm West Coast)
Any idea what unit these guys are? and what callsign they use?
Yes, to the first part. It's a LOT of time and effort to produce that. To do it, I've got to check logs from all over the place to see if anyone else has logged it to get an idea of flight direction.
00-9001 is one of the two C-32Bs owned by that unit - the 227th Special Operations Flight of the NJ-ANG at McGuire. Their other is 02-4452. They usually operate under callsign TERRA but they've also been noted using one-time callsigns. For instance, that 00-9001 was just on the west coast this past week using MANNY 72 for a call.
1147: Just had VADER 03 (C-130H, 89-9103, 757th AS Youngstown) land at BWI, then taxi to Signature Cargo ramp...119.4/121.9 (Once on the ground, I couldn't hear this aircraft. It's the only aircraft in memory that had a transmitter so weak that I couldn't hear it on the ground at BWI. Usually, I can hear a mouse fart in the corner of the hangar.)
Believe I've got another C-130 heading into BWI...trying to ID it.
1153: VADER 06 (C-130H, 89-9106, 757th AS Maxwell) lands at BWI...also heading to Signature ramp....119.4/121.9 (BWI Tower and Ground) (Oh-oh...I don't hear this one once on the ground either. They went to taxiways Poppa, then Bravo, then to Signature. A dead spot? Not usually.)
While listening to BWI Ground Control on 121.9, I heard JENA 106 (FBI Surveillance aircraft) request to taxi to the runway from Signature. He was approved to runway 33R. That was at 1207 and he went wheels up at 1211 w/Tower 119.4. I don't have an ID on the aircraft yet although it should be a Cessna 206/8.
There it is...there's a Cessna 208, registration N732MD in the area. I'm not positive of the association though. Call it only about 75% sure.
