1401: STEEL 61 tanker (KC-135, PA-ANG Pittsburgh) calling WARHAWK (Pax River Range controller) on «138.05» Don't think he's getting a reply. (I've also got a radio parked on 288.7 but hear nothing on that primary freq.)
1404: WILD 1 reporting mission results to SOF on «139.9» It is a flight of two WILDs and one SCARY. They all switch to V-6 on «139.15» to continue the trip home to Andrews. They report being 69 miles out.
1412: WILD 1 reporting to Reagan TRACON that he's from Baltimore to Andrews at 6,000 heading for runway 1R. «269.0» He's asking to descend to 4,000 and is approved. Cleared to 2,000 at 1414...says he's MARSA with SCARY and has the field in sight.
1415: Report from private plane that landings at Martin State are prohibited by winds. «121.8»
1418: WILD/SCARY flight talking about winds while landing are outside limits...one of them mentions 290/28 with gusts to 30-something. On Tower freq «349.0» They are arguing about whether it's safe or not...changing to SOF to talk about it and asking if those winds are within limits. «139.9» They say they still have a little gas time left so they can think about it for a bit. Flight leader goes back to Tower on «349.0» to ask for wind reading again. Back on SOF freq...flight leader says "We're going to land." And that puts an end to the argument. Back over to Tower freq they go and report on initial...they stayed at 2,000 feet through all the back and forth bickering about safety.
1425: BICEP/DEVIL flights still in the Pax River area on «138.3» DEVIL was supposed to be MARSA with the FLYER A-10s but I haven't heard FLYER in a long time.
1426: The WILD/SCARY flight is on the deck. «349.0»
1430: FLYER 11 flight with ZNY-Elk Mountain (Sector 51, Lake Henry) on «363.2» where they check in at 11,000.
NOTE: As soon as I get a chance, I'm going to change all the New York Center names to reflect their Sector names rather than area names so if all the ZNY freqs suddenly look different, that will be the reason. I did that with the Washington Center names some time ago.
1439: RISKY 91 flight (1st FW Langley) into GK's area working air space H and will stay east of the test track. «238.1»
NOTE: Something else to confuse me...we've had a SKATER 07 suddenly show up in the CAP several times in the past as the tanker support aircraft. I've always wondered why there would be a SKATER callsign when everyone else was using the TANKER callsign. Additionally, using the standard callsign list, we've always IDed him as being a KC-135R from the ME-ANG Bangor based on the SKATER call. Well...on his last mission, his flight plan shows him flying out of McGuire AFB NJ and going right back there after finishing his four hour shift in the CAP. So, I don't know if he was staging out of McGuire or whether that callsign belongs there.
1453: NJ F-16s still flying...they just went from «138.3» to V-17 on «138.875» and are lining up another attack and mention RTBing soon. They mention the maneuver is going to require them to be at speeds over 500 knots at low altitude.
1454: SPEEDO 81 (1st FW Langley) into GK's area using «238.1» will be in Kilo and wants to know if the test track is active.
1455: CRATE 91 flight (1st FW Langley) into GK's area...IDs as one F-15 into area W-72B for the next 15 minutes at FL230. He wants airspace India. «238.1»
1458: BICEP flight with Devil Ops SOF on «138.125» says the mission was awesome and everything went as fragged. Mentions deconflicting with F-16s and A-10s and it all worked great. He also wants maintenance to check this freq because it sounds like a live mic on it. They say they are 10 minutes from home.
1501: BICEP flight with ZDC-Casino on «285.4» and then with Atlantic City Approach on «327.125» where he mentions he's going to spiral down right where he is.
1501: The «138.3» flight is also active and it should be the DEVIL flight although it could be FLYER aircraft also since both the NJ and PA-ANG use that freq. I think the FLYERs have already gone home though.
1512: Hearing fighter activity on «141.675» (per carbineone's msg) It's about the same signal strength as the 138.3 activity - too weak to copy.
1515: A-10s from the MD-ANG at Martin State active on «142.3»
1518: WARDOG 1 (A-10 Martin State) reports 10 out, Code 1 to Raven Ops on «347.2» and Ma Raven asks for a PIREP when able.
1522: AXEMAN 1 (A-10 Martin State) reports 10 out, Code 1 to Raven Ops on «347.2» and Ma Raven asks for a PIREP for Patuxent (which tells us where he was) and he gives it to her...scattered cloud decks.
1525: Have an aircraft with Andrews Tower «118.4» saying the cross winds right now aren't bad.
At BWI at the same time, winds are at 26mph with gusts to 39.
1528: RAVEN 1 (A-10 Martin State) reports 10 out, Code 1 «347.2» Ma Raven repeats this info.
1534: RAVEN 1, flight of two A-10s, landing with Tower on «297.2»
1536: Sounds like a couple of Navy fighters with Pax River on «363.35» One of them mentions a warning light for his right rudder. He's asking the other for suggestions.
1540: After discussing it for a bit, they declare a "non-emergency, emergency" (there are a couple of aircraft now with the problem plane) «363.35»
1554: REACH 544 arriving from overseas and landing at Dover with CP on «349.4»
1600: And that's the end of my work day and so this is the END OF REPORT
carbineone: The CRETE callsign is used by A-10s of the CT-ANG at Bradley.
Just saw a news release from Verizon on the newswire that mentions parts of Columbia and Ellicott City are now on line with the new FiOS fiber system for internet at download speeds of 5, 15 and 30 mbps and upload at 5 mbps on the highest speed line (upload 2 mbps on the two lower priced services). The three speeds are priced at $34.95, $44.95 and $179.95 if you have phone service with Verizon, slightly higher if you don't. It also mentions that Howard County will have the new TV service over FiOS starting at the end of April. C'mon Anne Arundel County...where are you?
