jaymatt1978
Now THAT'S how you do an install!! Very nice setup!!
radmanrugg said:I was hoping the new unidens would be more red. To match my gauge cluster a bit better. I will see when it gets here.
Scott
radmanrugg said:Note that I cut a hole in the top of the pocket hole just below the scanner for speaker. I am looking for a remote speaker that will be self powered off the Uniden but am now waiting on the new scanner to decide what I want to do. Any suggestions for remote speakers?
Scott
Husky Floor Liners see forum post HERE for better pictures and description.dropkick said:What kind of floor mats are those?
pop out the cup holder. you should see a way to remove that. once thats out you can get your fingers in behind the radio / air control bezzel. its just snapped in there. mine was hard the first time I had it out. once you get it out a little bit you can work your fingers or other soft object down the sides to pop it down its length. once the bezzel is off you can remove the double dinn holder via 4 screws (2 per side some recessed more than others). The blank you have will come off the double dinn cage at that point.joshuadenny said:I hope this doesnt come across as stupid, but did you remove the console faceplate to do these? I thought about trying to pop it off to give myself more room to work with. I've got a hard plastic bracket sitting in the top of the 2 slots that I may have to just snap to remove, but oh well. any advice there?
