Summit County 800 System
rentacop
Barberton ,Ohio
Where would be the master control tower will be at or how many Towers will there be in Summit County
Sent from my LGMP260 using Tapatalk
northernsummit
Macedonia, Ohio
rentacop
Barberton ,Ohio
I'm having trouble hearing the Barberton Police Department in Norton Police Department New Franklin and others I'm hearing them coming in bits and pieces I'll need I like if somebody cable to help me to figure out how to get holding on to those or set the settings up properly to to do what I want to do with my scanner
Swipesy
Northern Ohio
I believe Hudson Pd Dispatch is TG 2661 on Summit P-25 System using the KW conversion method. Can anyone confirm before posting to RR Db?
rentacop
Barberton ,Ohio
I'm hearing that. Seen that talk group on my scanner but I do not know who it is but I'll keep an ear out to hear about any addresses or anything like that and sometimes I'm hearing bits and pieces of Barberton and Norton police and fire traffic on the simulcast system
KWs
Kent , Ohio
J
Hudson PD has not moved to new system ... You are hearing programming testing of new radios with Hudson. The new TG for Hudson PD was submitted, it is being held by RR database admin until Hudson officially moves.
rentacop
Barberton ,Ohio
I have a pro 651 scanner I'm here in bits and pieces of Barberton Police Department in Norton police department in Norton fire in Barberton Fire Department I need help to figure it out why it's doing that
N8YX
Which system in the RRDB is the new Barberton/Norton PD/FD dispatch system, and does anyone have a listing of talkgroups for those cities?
I quickly checked the MARCS-IP link but didn't turn up much.
N8YX
rentacop
Barberton ,Ohio
Summit County P25 system
I guess more changes are on the way for the new system a lot more fire departments and police departments that are switching over to the new system expected completion date is midpoint 2018
Nasby
Ohio
And most of the police departments will be fully encrypted. Some of the FD's will be too.
Sad times ahead for sure.
mszabo2000
Rootstown, Oh
Don't know where you get your info but most departments will be in the clear. Only one department is going full encryption and two are encrypting some tac channels. Plenty of traffic to listen to.
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
And what department is that?
MotorolaDave
Brunswick, Ohio
Thank you for clearing up the false info posted by another member. We know Akron is the department going to full time encryption. What are the 2 departments that plan to encrypt some of the tac channels?
