Sumter co SC
russellr51
Did you notice he’s not picking up Sumter County EMS either just picked up all Clarendon and Sumter fire but not EMS listen to the stream?
russellr51
There’s no way Sumter County EMS hasn’t had a call in between date 29 and now there are just as busy as Florence County?
russellr51
I have 4 sdr dongle two are versions 3 and other versions 3 powder by a usb hub with 4 800mhz antenna used by sds100 scanner ? There’s no reason why I can’t pick it up.
russellr51
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
So you're in Florence County but monitoring the Sumter simulcast site. Depending on where in Florence you're located, that could be challenging without a good antenna system.
OP made a claim in the first post that they've been broadcasting Sumter with no problems up until 5 (now 6?) days ago...
evan
South Carolina
The talkgroup is showing encrypted via the Richland County site. I'll update the database to reflect this.
brian
DB Administrator
South Carolina
I see the error in my logic. EMS Dispatch that appears in the live feed on OpenMHz is in fact Clarendon County EMS Dispatch. That's a inconvenience using that site, that it doesn't include the talkgroup category name as well as the talkgroup name.
I apologize for obfuscating the problem. Evan has confirmed that Sumter County EMS dispatch is now encrypted, so there is at least part of the answer. Why the OP isn't seeing the talkgroup activity in the SDRTrunk console and noting that it displays as Encrypted is another mystery, but perhaps that's no longer relevant to the discussion.
russellr51
so they encrypted EMS, but they didn’t encrypt fire yet so I guess they’re going to encrypt fire also
russellr51
Thank you so much, Brian I knew there was something going on
