SW Attic Antenna Question
Blueliner
Michigan
When the weather improves, I plant to use an existing but abandoned cable tv through hole in the house's brick and walls, by enlarging it with masonry drill and inserting a 1" pvc through pipe with a small weatherproof box on the outside. Whole thing caulked and insulated. Room for maybe 3 or 4 coax antenna leads.
tmhanser
I have to drill a fresh hole through the stucco and interior drywall, without hitting electrical lines or plumbing. No, I don't have the blueprints for the house, but I have a pretty accurate stud finder. Fingers crossed.
krokus
Southeastern Michigan
You could pull the old cable, then use a fiber optic camera to check for conflicts.
