hogshine
I just got a cobra 29ltd and a wilson 1000 magnet mount antenna and have had for a few years a Texas star DX 667V. Now to get you guys up to speed, I mounted the radio under my dash of my chevy pickup. Ran the power of the radio to the fuse box and hooked into the a fuse and grounded it there on the firewall frame. The antenna is placed on the bed rail of the passenger side of the truck with the coax cable ran from there to under the seat where the linear amp is. There is some extra so i coiled it together and zip tied it under the seat as well. And I also did the same thing for the other coax cable that goes from the linear amp to the radio and the is a little extra so i coiled it and zip tied it. Now the power supply for the linear amp is a the red wire (positive wire) to the battery and the negative or ground placed on a bolt connected to the frame.
Now my swr readings are 2 for channel 1 and 5 for channel 40. Obviously to high. So i went to adjust the antenna to pull it out a little because that is what wilson said to do, and i ran out of antenna to pull out with the swr reading still high. At this point i can talk and the radio Antenna warning light is not on.
So i went to turn on my texas star dx 667v amp on and the swr reading is way out of wack (extremely high) and the antenna warning light is on. Also my range sucked, I think i should be getting alot farther with 650 watts of power than like 5-6 miles.
I have heard that cobras do not like magnetic antennas an have also heard that the antenna warning lights have been sometimes set to strict but i don't think this is the case.
So I am asking what is wrong and what should i do to fix this problem? In any case i my swr is not low enough and i ran out of antenna to pull out to fix it so i don't know what to do. Hopefully you guys can help me out, thanks in advance for any help.
