Talk group ID
kd9dvp
Is there a Talk Group database for Knox County Indiana. I have downloaded my control channel and most TGID appear on my scanner 21464 etc. However, some ID'S are displayed that I have no idea of their display names 21353 etc. Any help is appreciated.
Enforcer52
Lake Livingston, TX
21353 is District 35 - Evansville Dispatch. Are you using a scanner or sdr? Sounds like you have ID Search turn on if a scanner, or an incomplete Alias list if using sdr's.
Using the list below, go to Edit in your browser window and put the number into the Find In Page field, and you can look them up.
kd9dvp
Thank You ! Using a BCD325p2, Should I use ID SCAN
Enforcer52
Lake Livingston, TX
ID Scan will only show/scan the TGIDs you have programmed into the scanner.
