Telewave 44A how to add the sample port
tropiradio
No, the connector flange on the Bird is larger.
Managed to find a couple of pictures off ebay, and it looks like the flange on the Bird is indeed larger so the bolt pattern would not align on the Telewave holes. Also on the Bird the isolator extends out a bit on the center pin that would also get in the way.
But the Bird 4275-020 sampler with NM/NF seems to be a viable option for an inter-brand solution.
prcguy
If you mix a Telewave father with a Bird mother the offspring will be a Diawa and most likely a bastard. Otherwise I would put female connectors on a Bird sampler and use a short cable between the meter rather than screwing a Bird sampler with male connector right onto a Telewave meter.
tropiradio
Actually it would be the other way round. Bird would be the father (NM) and Telewave the mother (NF).
wa8pyr
Staff member
Lead Database Admin
Ohio
Well, sometimes you just can’t tell these days.
What pronoun would it use? :D
But on topic…. I’ve used an iso-tee with great success, and it was a lot cheaper than fiddling with my wattmeter.
tropiradio
While checking out ebid for the first time found this sampler in the Radiocom section. Could not find it listed on ebay. No name brand visible (home made?), with main termination connectors being NM and 90-deg NF, with sample port (-30dB) being female SMA. Claimed operating range 70MHz to 2.5GHz, however no insertion loss or max power is specified, but assuming its a straight-thru probably good for a couple hundred watts?
Being sold by a "chap" over in the UK, price £27 (~$34) plus another 20£ for overseas shipping to US, which seems ok if this thingy really works as advertised. Not planning on ordering but out of curiosity wanted to put this out here and wondering if anyone is familiar or has ever seen/used this particular sampler.
More pics and info at listing here:
prcguy
I’ve not seen a Bird sampler like that. Probably a custom unit taken out of some surplus equipment.
