TERA TR-505 GMRS/MURS Recreational Handheld Radio
Some of the other Chinese radio grants have weird emissions designators like 5K and 9K that seem way to narrow for FM. I don't know what that's all about.
I always wondered if it was running narrower than necessary to cover them if the radio doesn't get aligned properly at the factory. Having a bit more "wiggle room" might prevent the stability issues of these low end radios from causing them to emit out of channel stuff.
bill4long
Indianapolis
Amazing how many of these companies will happily ignore the rules to make a few bucks. Integrity is gone, greed and profit has replaced it.
Lacking integrity for breaking idiotic rules? If the FCC would get off their dead rear ends and allow Part 90 certified radios to be used on GMRS and MURS, as long as the technical requirements and limits are met, then nobody would be breaking rules. People do it anyway, so it really doesn't matter what anything thinks of it. Blame the FCC for this. Their position is lazy, stupid and/or corrupt.
KD8DVR
Columbus, Ohio
Lucking integrity for breaking idiotic rules? If the FCC would get off their dead rear ends and allow Part 90 certified radios to be used on GMRS and MURS, as long as the technical requirements and limits are met, then nobody would be breaking rules. People do it anyway, so it really doesn't matter what anything thinks of it. Blame the FCC for this. Their position is lazy, stupid and/or corrupt.
Rules are rules, regardless if you think they are idiotic or not.
Yes, though, I totally agree there needs to be some updating of many of these outdated rules.
Perhaps, you should (or anyone) should submit a petition for rulemaking to the FCC? Anyone can do this... if they know how to format a proposal.
I have no problem breaking idiotic rules. Esp when there is zero enforcement. Cry all you want. No harm no foul.
We fully understand there are people like you in the world, and we know there is nothing we can do to change it, so do whatever you want.
But your argument is full of many flaws. Your justification is exactly what is wrong with the world, the "I don't agree with the laws/rules, therefore it's OK for me to ignore them".
Just what we need.
Sparky5019
Yes. They are factory programmed and work that way. I find it might prove necessary one day. Never know if you can help somebody out then. It's a great talk around radio. Almost hate making it duplex for local repeater pairs. Use it for sure talk around to clear busy repeater and close in group operation.
What kind of range do you get in talk around? Also, how easy is it to use for closed group comms?
Thanks!
K6LED
Long Beach, CA
Just FYI, I think they had the radio locked on low power for the FCC tests. It definitely puts out 4W on UHF, 5W on VHF (on hi power), and I've seen guys report that it is actually doing a bit more than that. ERP, of course, is a bit lower, which keeps it under the limits, esp. on low-power (2W VHF and 1W UHF, hence the 1.1W on the FCC test).
I know I can ping repeaters all the way across SoCal from inside my house with the rubber duckie, so it gets the job done. :)
PHRadio
I still wonder how it can pass certification for GMRS use when it also has VHF capabilities.
gewecke
Illinois
Seems like a neat handheld that does GMRS (+Repeaters) and MURS with a removable/detachable antenna.
TERA TR-505 GMRS/MURS Recreational Handheld Radio [TR-505] - $104.99
The FCC ID seems to be 2ACK8TR505, but I cannot find any part grants on the FCC database even though the website claims it to be Part 95 compliant.
Cheers,
Kermee
I know this is a bit dated but, this may have been merely a typo by Powerwerx since the Tr505 is merely a 16 channel Gmrs Repeater/simplex radio with no Vhf abilities, according to the specs on their website today. :). 73, n9zas
K6LED
Long Beach, CA
I think it's fine as long as it comes from the factory with only one service pre-programmed. At least that's the word for now.
As an after-market reseller, I offer the radio with the stock factory programming (all GMRS), but like many two-way radio resellers, I also offer custom programming with alternate settings.
I think if people use it responsibly, it doesn't pose a problem – not sure why we can't have both bands (at the proper power levels) and WX receive included - makes it a great emergency SHTF portable. ;)
PHRadio
Well okay then. :) They have changed it on their website. Does this mean I have to buy it. Please tell my wife I have to.
K6LED
Long Beach, CA
Actually, if you look closely, they still mention that it's a dual-band radio, but yeah, the factory configuration is just as a GMRS.
I don't think they will last long in this configuration - I know they're working on a way to make the "type-acceptance" less ambiguous. ;)
Until then, I'm grabbing as many as I can (and keeping a pile for myself).
gewecke
Illinois
Wifey of PH Radio; he has been ordered to purchase the Tr 505 gmrs radio :D. Yeah, upon going to the link the page was removed. But if you scroll down to the Terra brand of equipment then you would see the Tr 505 listed. No Murs ability though... 73, n9zas
nd5y
Wichita Falls, TX
There are three radios that look identical and three FCC IDs.
TR-500 VHF/UHF commercial
TR-505D GMRS/MURS
TR-505 GMRS only
They might all be the same hardware. I don't know if they are actually selling the TR-505D or if they ever did.
K6LED
Long Beach, CA
The TR-500 is the commercial radio version with Part 90 Cert. It's the same radio guts as the TR-505, but a different model and cert.
The TR-505D is indeed the radio that they are selling now. I'm a reseller and this is the one that I resell as well. There aren't many left though, but they will be replacing it with something that's locked down a bit more. :)
The TR-505 ID is the original/old cert, that didn't include all of the operating specs - It's still technically valid, but it was a screw-up and has been replaced by the TR505D.
Hope this helps.
PHRadio
Hahaha! Thanks! I think I will.
