Tetra decoding
sq5bpf
This is what I get when I try to install and if I try to install gnuradio it says that it can't find that package, but everything works great in debian.
if everything works great in debian, then just use debian :)
if you really want to install on kali, then find information how to install a recent version gnuradio. you're doing this on an unsupported OS, so you will have to do this yourself, but this shouldn't be a problem. if the install script finds that gnuradio is already installed, then it will skip this step.
tripadvisor
Yes, thank you, but still it is strange, because before this latest version of kali, everything was working fine, but now something happend. So the thing is that my PC isn't so good enough to run telive in debian, but kali works best for me, so I guess I will have to fix this problem with kali manually.
hamradionl
Iam not a linux gourou (yet) but give it a try to ask advice
Got linux mint + telive running for long time on older duo-core PC, without problems
Buy myself new i5 PC install linux mint 64 bit = OKE
Install telive = OK
after start GNU radio, get this message
Warning: failed to XInitThreads()
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.009.003-release
gr::fft: can't import wisdom from /home/xxxxxxxx/.gr_fftw_wisdom
Using Volk machine: avx2_64_mmx_orc
Xlib: extension "GLX" missing on display ":0.0".
Any advices be welcomed
sq5bpf
i've made a small fix to osmo-tetra-sq5bpf , please update
this fixes garbage SSIs appearing and also sets the -r -s options in receiver1* scripts
please report any success or bugs
hamradionl
sq5bpf;
Thank you.
did new install on debian 8.0.6 also new install MINT 17.3,
Both run OK on i5 machine in very good quality voice
mescalero
please explain what doesn't work, please provide error messages etc
Sorry...
I demand better
From "tetra" folder..
the upgrade process is the same as described in the previous .pdf
on page 1 (wget https: raw.githubsercontent .... etc.)
chmod 755 install_telive.sh
./install_telive.sh
correct? the version number displayed is always 1.9?
thank you
sq5bpf
install_telive.sh installs a lot of software:
telive: the version is still 1.9 (ok, there have been some updates without changing the version, but not recently)
osmo-tetra-sq5bpf: there is no versioning. check out the git log in your local repository if you're interested what changes were made and when
tetra codec: this has been unchanged fo a long time
libosmocore-sq5bpf: actually this is the original version of libosmocore from Osmocom, but kept at the state from 2014.
so the fact that you're still seeing 1.9 means only that telive is at version 1.9
mescalero
thank you so much
I wanted to confirm that he had misheard
now everything is more clear
the update command is right and the procedure also
greetings from Rome and excuse me for bad question
I am "newbie" hii
Iw0cql Maurizio
Ramunas
Hi all,
After upgrade as described in page 56, all was work fine, but in second day I get error - python 2677.and so persisted.Maybe something can advise where is the problem.
Thanks,
mescalero
Hi all,
Thanks,
Same message
my syntax is
./receiver1udp 1
Work perfect
Ramunas
Thanks dear mescalero,
Yes, with ./receiver1udp 1 all working super, I get error with ./receiver1 1 , thanks for help.Sorry but I still have one question- I nohow cant activate new comand -e, when I press e key, indicate that this is unknow key?
sq5bpf
add -e to the tetra-rx arguments, for example in the receiver1udp script that you're using
btw -e is for research only, it will show garbage data if there is any encrypted traffic. i don't recommend it for normal use
michelinok
Hi!
I've a strange problem the the grc under linux...
They works only first time i run them, from the second time i get no interface, rebooting works 8only first time).
Any ideas?
The installation in clean (installed everything,ubuntu 16.04 too, just yesterday).
tripadvisor
After updating everything on debian this error is shown when I open gnuradio flowgraph doesn't matter if it's receiver_udp or receiver_pipe
Error 0:
Block - freq_xlating_fir_filter_xxx_0 - Frequency Xlating FIR Filter(freq_xlating_fir_filter_xxx):
Sink - in(0):
Port is not connected.
tripadvisor
Ok, I reinstalled everything and now works ok. Thanks for -r -s flags, now I can see SDS messages sent to units from server.
oz1jua
Copenhagen
Play message number ?
what is the number placed in play line ex. 62233 [1]
It is only there some times....
