Texas DPS Re-Numbering...
owtlawatv
Corpus Christi, TX
anyone know if I can tune to DPS in Corpus Christi?
we have a DPS office here but I cant seem to find radio info on them.
Im picking up a 106 from radio shack so I should be able to tune to them if the freqs are available...
mass-man
trying to retire...
Parker Co., TX
The Database tab at the top of the page is your ticket to CC DPS nirvana! Be sure to read about downloading direct into your Pro 106 with software. Makes life so much easier.
texasemt13
CenTex DBA
Hunter, TX
owtlaw, there is no stumbling involved around RR.
First, click "Database" in the blue toolbar above. Then select "Texas" on the map. Under the "Texas State Agencies" dropdown menu, select "Department of Public Safety (DPS)" and click the "Retrieve" button.
In the DPS database page, there is a statewide channel plan at the top (below the region map). You'll notice that the frequencies and NACs are recycled throughout the state, in a pattern where they won't interfere with each other. Scroll down to Region 3, and you can see the frequencies (base/mobile pairs and repeaters) specific to your area. Do some searching around the Texas forums for how DPS operates...
Sometimes you'll only hear one side of the conversation, for two reasons (and this is what I mean by searching the Forum). One reason is that the dispatcher is constantly monitoring many frequencies, and when she responds to one of the troopers in the field, she will be broadcasting on all of her linked sites. That's the reason you'll hear the trooper unit number during each transmission (so the other troopers know who she is talking to). The other reason you'' only hear one side is called half-duplex (for the base/mobile pairs). If you're interested enough, I'll explain that one later.
al95
Brownsville,Texas
I was stop by DPS this morning for an expired inspection sticker. The car was not mine I was helping my friend take it to the repair shop. I was given a ticket for it. Within minutes after she let me go I went to a local inspection shop and got it renewed. I hope the judge is nice enough to dismiss the ticket. BTW it expired on 01-01-2010. In the ticket it had her badge number 12988 region 3 distict A
Area 9.
Ensnared
Waco, Texas
Question
I cannot recall who, but someone told me that the best way to program DPS in the RR DB was by: a) de-activating duplicate frequency function; & b) show input frequencies. Is this the way to do it?
Ensnared
Waco, Texas
Today, I heard DPS using the KKC523 here in Waco. This traffic was intercepted on DPS B1. Dispatch identified themselves as Waco. Also, the mobile unit called requesting Waco to answer. So, it does not seem the migration to the other dispatch locations has taken place here.
texasemt13
CenTex DBA
Hunter, TX
I might have misread the information on DPS since I thought dispatch was being moved to San Antonio. Thanks.
Check the DPS Wiki, I listed all the known ones there, when the info first came out. It's probably not 100% complete/accurate (one article said they were closing 10 and didn't mention if that included recently closed ones, another mentioned only 7). I don't see Lampasas on that list, but don't hold your breath. All this is half speculation.
Since DPS changed their repeater designations I need to go in and change the linked repeater tables in the Wiki...
texasemt13
CenTex DBA
Hunter, TX
BTW, and this is probably a question suited best for a DBA:
Why is DPS Kerrville still in the database? The Kerrville Comm Center closed awhile back, and as far as I know all the repeaters are handled by San Antonio (I know for a fact that the main one, Base A, is).
Boulder
Wood County, TX
I caught DPS 128 calling DPS Dallas last night saying they were clear of Sulphur Springs airport and en-route back to Longview Gregg County Airport, so this must be the new DPS Helo that is stationed in Longview.
al95
Brownsville,Texas
For many years I have heard DPS calling McAllen or Harlingen Communications station. This morning I have just notice DPS calling a new station in Weslaco,Texas. Is there a new station in Weslaco,tx? I have not heard them mention say the harlingen, or mcallen,tx station. Are this stations now closed?
al95
Brownsville,Texas
They built a new regional headquarters in Weslaco. I'm not sure when it opened or which stations closed and moved there.
Hey thanks for the quick response. When a DPS officer talks he first mentions Weslaco then his badge# last the information he whats. The dispatch answers with Weslaco and in the end of transmission the dispatch say weslaco then the station callsign. They do it in every call.
texasemt13
CenTex DBA
Hunter, TX
al95,
The format you mentioned is pretty standard across the state, however you probably also hear the dispatchers respond by saying "Weslaco, DPS unit number (that they're responding to), the information given, then the callsign." Since these dispatchers broadcast on multiple sites at a time, they usually respond to troopers by repeating their unit number, so troopers in the field who can only hear the dispatcher, know to whom the dispatcher is speaking.
al95
Brownsville,Texas
al95,
You are correct. I just heard this while responding to this post on my PRO-106.
Myles
Houston TX
So is it concluded that DPS mobiles do not use 155.445, 155.460 or 159.2175 as mobile car-car channels? Does anyone know for certain what (if any) channels are used (possibly 154.950 and 155.475)? Apparently they use 159.075, 159.090 and 156.2175 for special operations. Maybe some of the VTAC channels? Is CTAC no longer part of the Texas plan? Guess that was analog.
nd5y
Wichita Falls, TX
Since they went P25 a few years ago have heard simplex on 155.46, 155.445, 155.505, and 159.09 here in Mineral Wells. Sometimes they just use the repeater. They also have a bootleg channel that they call 'Floydada' on 155.910 CSQ. I don't know why and that frequency isn't even licensed in Floydada or Floyd county and it is adjacent to a Palo Pinto County repeater on 155.9025. I don't know if it is used anywhere else. I don't think CTAC was ever implemented. It isn't in any of the current interop plans.
