I've noticed narrowing the bandwidth a little helps with noise on the weaker stations.
Yep, it does help some and I have tried that too. I would suggest anyone try that. I really can't complain much about the radio. For the price and size it is impressive, if it had an RF gain it would be a stellar performer.I've noticed narrowing the bandwidth a little helps with noise on the weaker stations.
It says in a manual I found online (no block diagram, unfortunately) that the Eton Elite Executive has SYNC (a synchronous detector function), so it may not have a DSP chip inside, it may be analog superhet.Whatever the design, it isn't possible to improve the signal-to-noise ratio. It works just fine for what it is and pulls in signals well. I do get a little fatigued listening to all the background noise. If anyone has found a block diagram or schematic for the Eton Elite Executive, I would really like to see how it is designed.
Yes. The SYNC button seems to help with AM broadcast fade. Isn't that what it is for? Seems to lower distortion and some improvement in SNR. Isn't it Synchronous AM demodulation? It sometimes adds tons of noise to reception of SSB. I have accidentally enabled it when switching to SSB.I don't recommend using the synchronous detection button on the radio. You are better off using straight SSB and using the fine tuning.
Tried one years ago. That amplifier adds lots of noise. Where there is room, I usually use inverted V antennas. Best overall performance of any wire antenna I have ever tried. They are not as much affected by elevation off the ground as are horizontal dipoles. Do not pick up so much noise as a vertical and they are omnidirectional. Currently have a 20/40 meter inverted V in the back yard. Apex at 25 feet. One inverted dipole for 20 meters and another for 40 meters. It does very well as a SWL antenna too. Works good plugged into the Eton. Where space does not allow as with portable operation, I reluctantly use verticals. It is hard to get enough elevation for horizontals, and they are directional. I don't use them. I just recently strung up a hoist and cable about 60 feet into a tree. Actually the tree trimming guys did it for me. I plan to get a multiband inverted V farther off the ground.Have you ever considered << THIS ADD ON ITEM >>?
... and it looks like it comes with a stand for the radio too!
Howdy,
I'm another lurker from Washington (the "Other Washington" as we like to say).
Here are a group of links to various software packages for decoding WEFAX on a PC: https://www.dxzone.com/catalog/Software/Weather_and_FAX/
There's at least one Android app for WEFAX, so if you have an Android device you can decode WEFAX without even needing the line input. This looks very capable, and the cost is $9.99: HF Weather Fax decoder for Android phones & tablets – Wolphi – Mobile Software Development The same company also offers Android apps that decode PSK, RTTY, and other modes.
For SSTV, I recently downloaded Robot36, a free Android app: Robot36 - SSTV Image Decoder - Apps on Google Play
