TK-2180-K2 - check model name and market code
mikepdx
Corbett, OR USA
Hello all.
I'm afraid this is yet another " Check model number and market code" thread.
I have read, and re-read several threads on the subject,
but many are so convoluted, and refer to other models.
I cannot interpret the definitive answer if there is one.
I am using KPG-89D v1.61
I use it regularly with success on another TK-2180 I have.
I have Model Information set on TK-2180Portable 136-174 MHz and it shows FleetSync by default.
The problem child:
A TK-2180-K2 I just bought recently.
Appears to be operating perfectly as is
Here's what is on the back:
On the silver sticker: TK-2180-K2
then on another sticker (white) with 2 bar codes it says: TK-2180 019048 156174
On yet another small sticker with no bar code, it says: 036/06/123046
- Can anyone give me a definitive answer on this issue please?
- Also, what button sequence on power up shows the Firmware version?
- How do I determine the checksum & what is the latest Firmware version released?
So, so many questions, but I know many industry experts are here and eager to help.
Thank you all for the enormous help you've given
throughout the years.
- Mike in Oregon (yeah, a longtime ham)
kd4efm
EL98 Florida
Does it say anything during boot up?
Tools, transceiver information, does it give you any info?
mikepdx
Corbett, OR USA
The radio itself of course beeps, the zone name appears,
and then normal operation.
The software gives no errors on startup.
mikepdx
Corbett, OR USA
Oh, one other tidbit:
When I power up the transceiver holding
the PF button above the PTT, it shows
E 1.04.00 for an instant.
Presumably that is the FW version.
mikepdx
Corbett, OR USA
UPDATE:
Grrrr.
I jumped the gun by posting here.
Should have done a bit more research.
That 'E' means Euro Model.
It uses KPG-92D CPS for European Versions.
The '92' works just fine.
Don't ask how fast I acquired the SW.
One oddball thing is that the wide/narrow options are this:
Wide 4K, Wide 5K and Narrow.
I want to find out what exactly they mean by
seeking a SM or Brochure on the web.
I am sitting here right now listening to our local NOAA on 162.55 MHz
Sounds perfect.
The mods can probably close this thread.
Hopefully it's useful to someone else with this "issue".
Echo4Thirty
Colorado Springs, CO
UPDATE:
Grrrr.
Sounds perfect.
WIDE 5k - The normal 25 kHz bandwidth we in the US refer to as wideband (5 kHz deviation)
WIDE 4k - Not really used on VHF/UHF here, but I have seen it on 800 MHz. Its 20 kHz bandwidth / 4 kHz deviation)
NARROW - This is the usual narrowband, 12.5 kHz bandwidth / 2.5 kHz deviation.
If you have a copy of K (US) firmware, you may be able to flash it back to KPG-89D software.
