TK 5210 Channel Knob
Ok so id really like the ch knob to spin continuously on my TK5210 so i can have more than 16 channels in the bank and not have to use ch up and down buttons. I called the Kenwood Depot the other day to ask if it can be done and he said sure just take the stop off the bottom of the knob. So to test this out i took the knob off and used needle nose pliers to turn the knob but no luck it stops at both ends. Has anyone else looked into this? On a side note any one know why all p25 radios only have 16 ch knobs?
cwb212001
Spokane, WA
I'm not sure if this will help you as it is not a direct answer your question... I just assembled a TK290 that included a channel stopper ring. This is a flat ring with a tab on one side bent perpendicular to the ring. This is apparently used if you want to limit the 16 channel selector knob to 8 or 4 channels as indicated by the included optional sticker rings that could go around the knob. I haven't ever had a request for doing this, nor attempted to figure it out, nor do I think that the radios are that similar. But in case they are I'd look for that ring to remove or whatever is attached to the knob that keeps it from moving in a 360. Good luck
ramal121
Lots and lots of watts
Calif Whine Country
You have a 5210, what type? Do you have a LCD display or just the basic model (no display)?
5210
Sorry for not being more specific. i have a k2 ver 1 and a k7 ver 2. The stop ring is on there but even with out it it stops i believe its inside the selector switch that its limited.
dj25705
Not sure on the 5210s but the 5220s you can remove the tab and remove the check mark for "16 Zone/Channel Selector" in the software. This enables you have more than 16 channels in one zone.
