TK-790H Question
Now onto the next issue...I can't hear the repeater coming back to me on this radio, but I can on other radios. I can get into the repeater just fine with the radio and the PL isn't needed on RX, just TX. Switching the coax between Radio A (TK-790H) and Radio B (NX-700) isn't feasible with ease and I can't put up another antenna.
Can you hear anything on the radio? Program in a NOAA frequency and see if you can hear that.
KCH-10 head has a built in speaker, but needs a jumper on the back to make that speaker work. It's the square 9 pin connector. You'll need a jumper between pins 3 and 6 to make the internal speaker work.
KCH-11 has no built in speaker and will require one.
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
Jumper wire is installed. This used to be my mobile rig. I can hear our local Fire Dispatches for the county along with the next counties Sheriff channels just fine.
I can hear other repeaters come back to me just fine too. It's just this ONE PARTICULAR repeater it seems. Yes the frequencies for it are correct too. It's 147.195+ PL 123 so simple stuff! 147.180+ PL 88.5 works fine but that's a ton of miles closer too!
Regards,
-Frank C.
Could be an alignment issue with this radio.
Could be the repeater has it's deviation set low.
Could be that the repeater is down, or not hearing you. 110 watts may not overcome other issues.
If it works everywhere else, my money is on an issue with this particular repeater.
kg6nlw
Repeater is definitely hearing me because when I A/B between the TK-790 and the NX-700. I get full audio back on the NX-700...So could it be an alignment issue with the radio, despite just coming back from a trusted shop? IIRC there was something funky with the 790's that you had to change to get ham to work 100% right at one point?? It's been forever since I had to worry about that or fiddle with this radio.
Regards,
-Frank C.
OK, that's a good clue.
Double check your programming. Yeah, I know, you already did. Check it a third time. Make sure you have the PL set as 123.0Hz, and not DPL123. Make sure it's set for wide FM, not narrow.
Did you try it in carrier squelch?
If the radio works fine -except- on this one repeater, that likely means there's a repeater issue (likely ruled out with the NX-700), or a programming issue in the TK-790. Probably a few other things, but those are the two easy ones.
kg6nlw
This is how I have it programmed into ALL my radios, works fine everywhere else. I have noticed one other machine 147.315 is not responsive and that is a much closer to me machine and I can get into that with the NX-700 as well.
Regards,
-Frank C.
Just for kicks, try selecting the "Beat Shift" option. If it's an internal oscillator thing (aka: birdie), that might fix it.
AM909
Radio/computer geek
SoCal
What exactly is happening? Are you saying that you can plug the NX-700 into exactly the same power and antenna and hear people talking when you heard nothing with the TK-790? Or are you trying to kerchunk it (and it might have a kerchunk filter)? Are the other repeaters you hear OK lower or higher in frequency? Do you hear them with the same amount of quieting (same signal strength) as the NX-700 if plugged into the same antenna?
n7maq-1
Oregon
Another thing to look at if you are using the rear PTT. You should have no problem hitting that repeater, he has a ton of RX sites and it is a voted system IIRC.
kg6nlw
Yes, I can transmit and receive normally on the NX-700 into the N6ICW system, I can transmit into the N6ICW system on the TK-790 but I can not hear the repeater come back to me.
The other repeaters are stronger because they are closer to me.
That is only for PTT output, the issue I am having is receiving! I can PTT out just fine, it's the RX that is the issue.
Regards,
-Frank C.
AM909
Radio/computer geek
SoCal
Does the busy light come on, but no audio? Or no busy light? Have you tried opening the squelch all the way (I forget what numeric direction that is) and do you hear white noise?
kg6nlw
No busy light at all, squelch all the way open doesn't matter. I think I have to get it re-aligned again...
Regards,
-Frank C.
