Kenwood: TM-281 programming?
N5TWB
Sand Springs OK
I’m assisting a 98-year-young ham with his new radio & part of the programming has stumped me. The ham is legally blind so using the controls is difficult. His preferred local repeater doesn’t use PL and was easy to program once I deciphered the key sequence. His son-in-law thought it would be good to have some of the other local repeaters programmed in the memory. I put in a couple that use a PL & could not figure out how to get the memory to turn on the PL automatically. It would hold the tone yet had no place in the memory list where it was toggled on when switched to that location in memory. You could go to that memory location & press F then Tone but there’s no way the legally blind ham can reliably do that. The manual says it is one of the memory parameters but I can’t figure out how to do it. TIA for any assistance.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
With most amateur radios, if you select the PL mode and frequency PRIOR to saving the channel to memory, the PL information will be retained and automatically utilized whenever that memory channel is selected. Selecting PL is normally a two-step process... first select the "tone' (encode) function, and then select the correct tone frequency needed to access the repeater, then save the channel to memory.
Hope this helps.
N5TWB
Sand Springs OK
Hope this helps.
Your recommendation is exactly how the manual has you set up a memory location and then acts like it’s not there when that memory is selected. The only way I was able to get the “T” indicator on the screen is to activate it manually with the “F” the “Tone” keystrokes.
wrath
If he has a visual impairment why did you get a 281 ? The V71/710 has a speech and storage chip available,it will tell you everything on the display ,including mode .
I have them and it's a great help everytime you hit a key or change modes it tells you what you have done,
Also if you need a talking SWR /power meter MTC in Texas has them .
Sent from my SM-T810 using Tapatalk
AK9R
Staff member
Super Moderator
Central Indiana
I've not used a TM-281, but if it's like other Kenwood mobiles, configure a repeater with the correct frequency and tone in the VFO, then do a Memory Write keystroke [F], [MR] to save the VFO to a memory channel. All of the parameters you configured should be saved.
robertmac
Follow the TFM as it is stated in there. If this doesn't get the PL and frequency into memory, explain exactly what you are doing in order. This may help someone know what steps or steps you are doing incorrectly
N5TWB
Sand Springs OK
Good points on assistive technology but I don’t get where you think I bought the radio. The ham’s son-sin-law bought it for him after his previous radio of 1980’s vintage quit working. The SIL contacted me because my name was on the club website.
N5TWB
Sand Springs OK
Did exactly that and it does save those parameters with the keystrokes you state. What is missing is a step while in VFO mode to switch on the Tone function. From your input and on thinking about it a little, I’ll go visit him again this week to try something that I don’t recall being in the manual of doing the F/Tone keystrokes while in VFO mode before doing the F/MR memory storage.
Your input is rude and not helpful. Please keep your disrespectful language some place other than my thread.
AK9R
Staff member
Super Moderator
Central Indiana
I don't think it's rude, disrespectful, or unhelpful to ask someone to read The Fine Manual.
We are trying to help you. The manual clearly states on page 29 to start in VFO mode, select your frequency, select the repeater offset, select the tone and CTCSS/DCS function, and then save all those settings into a memory. If those steps are followed on every Kenwood mobile radio I've ever owned (at least 6 of them), all of the settings are saved and you don't have to re-enter them again.
N5TWB
Sand Springs OK
Ok, it’s a “fine” manual & it does state exactly as you write (working from memory here) yet there is no step to turn on the tone function in the memory. Just entering Tone data in the memory does not turn on the function. I followed the steps on page 29 with information for a local repeater with PL and saved it to a memory. Upon switching to that memory, I attempted to contact the repeater without success. Using the F - Tone sequence while still in memory mode turned on the programmed PL & I was able to connect to the repeater.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Do the following steps in the following order:
Step 1: set your receive frequency and transmit offset in the VFO.
Step 2:
Turn on PL encode(Tone), PL encode/decode(CTCSS) or DPL encode/decode(DCS)
Step 3:
Select the tone/code you need to access the repeater.
Next post will contain the final steps to store. Tapatalk won’t let me load more than 2 images.
kayn1n32008
Sector 001
Now follow steps 2 through 6 in the following 2 images to save to memory:
N5TWB
Sand Springs OK
Step 2:
Step 3:
Your sequence is what is I was referring to in my Post #8. I will do it this week after I make arrangements to stop by the gentleman's apartment. I've also re-read the online manual and now see where the tone is activated in the programming sequence.
