Towns County, GA going Digital
trwmodela
Fort Myers, FL
There are several upgrades coming to Towns County 911 system. One includes changing to digital from the current analog system. I am trying to find out what type of digital system they will be using? The plans call for everything to be up and operational by April of 2020.
  • Like
Reactions: RRR
Vern
Union County, GA
If you look at the FCC licenses for their current public safety channels, go to the FREQUENCIES tab, then select EMISSIONS and you'll see multiple designators. The one that's probably of most interest to you is this one:
4K00F1E, which translates to NXDN 6.25 kHz digital voice (IDAS, NEXEDGE).
Towns County's neighbor, Union County, switched this past summer from analog-only to Mixed Mode (6.25 kHz NXDN digital & analog).
The fire tone-outs haven't changed, they just sound a little different than they did on analog. Union uses Kenwood repeaters, mobiles and portables.
trwmodela
Fort Myers, FL
Vern, great information as system upgrades are expected around April of 2020. My current Motorola equipment, Minitor V pager and a CP200XLS portable will not work. My desire is a tone activated radio, that scans and can be programed. I don't need to TX side of the radio because I only monitor calls. A Kenwood Protalk Digital NXDN Series UHF CQINX340U16P work? they sell for about $329.00 but I need software to program it. Now, I am assuming they are staying on UHF, if I am reading the information correctly? Any expert advice is greatly appreciated. BTW, I spend about 5-1/2 months in Towns County each summer.
Vern
Union County, GA
A couple of things based on your latest message:
1) The bulk of Towns County's public safety licenses appear to be VHF in the 151-159 MHz range. The School system has a UHF (461 MHz) freq. Hiawassee uses VHF for local government and water utility but also has a UHF freq for the water dept. Young Harris uses UHF for their water utilities and the YH College uses UHF as well.
I doubt that their system is so busy that you'd need to rely on tone activation. Either scanning them all or leaving it on the FD dispatch channel probably won't drive you crazy.
2) I'm no expert on Kenwood radios, but when I first looked into getting one I downloaded their manuals. It appeared to me that the Kenwood ProTalk series radios are pre-programmed with a table of business band frequencies. I didn't see where you could program them with a public safety freq that wasn't already embedded in the radio's pre-programmed table. I could have misread it but that's why I avoided them as NXDN scanners. There are lots of used NXDN radios on the market. These radios are mostly mono-banders, so choose your band first. Kenwood's NXDN radios are easy to spot as their model numbers all start with "NX".
3) I like the NX-200, NX-220 for VHF HT's and the NX-700, NX-720 for VHF mobiles. The 200/700 series both use the KPG-111D software and the 220/720 series both use the KPG-141D software. The software is available on ebay for about $14. The learning curve exists but isn't too awful. There is an easy way to inhibit transmit on any channel... enter a RECEIVE frequency and it automatically populates the TX column with the same freq. Simply erase the TX frequency completely and the radio won't transmit on that channel.
4) If you choose the 220/720 series then there are some combination programming cables that have both the 2-pin connector for the HT's and an RJ45 connector for the mobiles. (Ebay approx. $13) I already had a USB-to-Serial adapter with an FTDI chip that works with my laptop so this was a no-brainer.
Good luck.
Vern
trwmodela
Fort Myers, FL
Vern, I need the tone activation features to avoid having to monitor the open frequency at night. My Motorola minitor V is set for All Call and Fire Station No 3 at tones only at night. This allows me to hear EMS/Fire dispatches near my cabin only. During the day I usually just monitor the frequency. I do program my Motorola’s both pagers and portables. Time to look on EBay for some Kenwood radios.
Thanks for the information & advice......Tim
  • Like
Reactions: RRR
trwmodela
Fort Myers, FL
Vern, I went ahead and purchased both KPG-111D & KPG-141D software. Also purchased the USB programming cable for the NX-200 model. Do you know if both NX-200 & NX-220 both have the tone alert feature? BTW...downloaded both manuals too, need to check them out.
Vern
Union County, GA
I don't use it so I am not familiar with how that is programmed into the radios so I can't say if any particularmodel supports it. I do know that there are a lot of signaling options. Maybe the manual will enlighten that topic.
The software has good context-related help files.
Vern
Union County, GA
Towns County, GA went live with NXDN digital on Sunday, January 5th, 2020......
It might be MIXED MODE as I've heard both analog and NXDN (6.25 kHz) traffic.
The NXDN on 155.580 (S.O.) and 154.415 (F.D.) both had a RAN of 25.
I haven't heard the EMS repeater today so I can't verify it's RAN code. [UPDATE: EMS uses RAN 25 also.]
If you have an analog scanner that accepts PL tones, use the PL's for tone squelch so that you can hear the analog traffic but won't hear the digital datastreams.
73 de Vern
Airboss
Silent Key
Brasstown, NC
I can confirm the SO dispatch on 155.580 using NXDN RAM25. Will look at the rest as we here it. Towns Co is our next door neighbor here in Clay Co NC.
trwmodela
Fort Myers, FL
Towns County EMS Dispatches are using 154.1000 with RAN of 25? Now knowing FIRE, EMS & SHERIFF are their any other public safety NXDN frequencies being used?
Airboss
Silent Key
Brasstown, NC
Last night Towns SO was using their analog system again. When I caught them in NXDN it was the dispatcher and SO units 113/117. I still have not heard any other PS agency in the county using digital yet. More when I get something new to share.
Smitch2377
Dacula, GA
Did Towns change the frequency? I have a digital Sds100 with NXDN. Pick up Clay Co fine. Towns is silent.
