Tram Browning Junk?
Robotech2112
Carbon Unit.
Lenawee/ Monroe Line, Michigan
I have a BR-6283 that I installed on my roof 30 feet up for the purpose of 800 Mhz monitoring. Coax 50 ft of RG-213. I could barely hear anything beyond 8 miles. I checked coax, connectors and came to conclusion that the antenna is defective.
I live in Dundee Twp , MI and could not receive the Washtenaw Co site for MPSCS tower at Bemis Rd some 8 miles north with this BR-6283. Get this... I installed my 2 meter Ringo Ranger on the same tripod and can now receive the Bemis Rd tower site with no clipping. A 2 meter ( 20 years old too)..outperforming a supposed 800 MHZ 3db gain antenna?
I measured the resistance with a DMM; center conductor to the outer conductor on this Tram Browning BR-6283 and I get almost 0 Ohms. Is this right? Or is this antenna shorted out?
Any experience with Antenna Farm on defective returns?
QUESTION #2> Regards Washtenaw County Sheriff Michigan Main TGID. The data base has listings for EAST and WEST Dispatch. I only seem to pick up Ann Arbor City Police on the TGID 2191 for WEST.
Where is WCSD Dispatch WEST?
Thanks.
ko6jw_2
Santa Ynez, CA
How did you check the coax and connectors? Did you try them with another antenna?
A 0 ohm reading may not indicate a short. What is a low resistance at DC is not necessarily an RF short. It depends on the antenna design. Your Ringo Ranger will show a DC short because of the way its fed.
The antenna you bought is a 5/8 wave and should not present a DC short. Did you test the antenna without the coax? I've looked at this antenna and am not sure from the picture how it works because normally a 5/8 wave antenna requires a ground plane.
You have not isolated all the variables based on what you are telling us and so its hard to tell where the problem is.
Robotech2112
Carbon Unit.
Thanks for your reply.
I did try the coax and connectors with another antenna after I did a continuity check on both. Coax and connectors passed with flying colors. I then hooked them up to my 2 meter Ringo Ranger cut to 28 inches and it works really well. It out performs this Tram Browning antenna I speak of.
I also tested this antenna without thew coax and used a coat hanger wire to connect it to the back of the scanner. The telescopic antenna that came with the BCD996XT out performed this Tram by a long ways.
Even a Monroe County Tower site that is 6 miles away would come in "clipping audio" with the Tram hooked to back of set, whereas the telescopic is near full quieting.
I AM picking up the Washtenaw Tower on Bemis Rd at US-23 with the Ringo on the roof at 30 ft whereas the Tram did not receive it at all. I live near Cabelas (SW). There are no variables remaining but the Tram Antenna. I honestly believe I got a bad one.
nanoject
It could be the antenna is picking up more/stronger radio signals and this could create Intermod/overload and desense the frontend of the radio. Have you tried another radio? Do you have a nearby cell tower?
