Transfer data
krokus
Southeastern Michigan
Keep in mind that you will lose the programming of the scanner on the receiving side of the cloning. Using your preferred programming software allows you to keep a copy of the configuration, to re-load, if wanted.
Sent via Tapatalk
kc4jgc
Virginia Beach, VA
However, if you were to change the recieving scanner to an empty virtual scanner before cloning, you can keep BOTH configurations. All you need to do is switch between the two, if needed.
