Trunk Recorder error question:
kslager
Can someone tell me exactly what is going on here? It seems like just in the last few days, I've had to power cycle the pi daily. I am running a pi 4 4GB with one RTL-SDR using the Broadcastfy image. Once I power cycle the pi, everything starts working again for a while. I have 2 small nodes on the same pi/sdr. Should they be separate? I have another single node on a pi, and it seems to run without any hiccups. Log attached below, followed by config file. Thanks!
Code:
[2021-05-19 03:32:18.470666] (info)   [ISICS-Bradgate]    TG: [35m     13601[0m    Freq: 7.699688e+08    TG not in Talkgroup File
[2021-05-19 03:32:18.470872] (info)       - Starting P25 Recorder Num [0]    TG: [35m     13601[0m    Freq: 7.699688e+08     TDMA: true    Slot: 0    Mod: true
[2021-05-19 03:32:18.471026] (info)   [ISICS-Bradgate]    TG: [35m     13601[0m    Freq: 7.699688e+08    [32mStarting Recorder on Src: rtl=0[0m
[2021-05-19 03:32:34.344794] (info)   [ISICS-Bradgate]    TG: [35m     13601[0m    Freq: 7.697188e+08    Update Retuning - New Freq: 7.697188e+08    Elapsed: 16s     Since update: 2s
[2021-05-19 03:32:43.730496] (info)        - Message -     TMDA: true     Slot: 1    Call -     TMDA: true    Slot: 0
[2021-05-19 03:32:43.730597] (info)   [ISICS-Bradgate]    TG: [35m     13601[0m    Freq: 7.697188e+08    Update Retuning - New Freq: 7.697188e+08    Elapsed: 25s     Since update: 2s
[2021-05-19 03:33:20.000410] (info)   [ISICS-Bradgate]    TG: [35m     13601[0m    Freq: 7.697188e+08    Ending Recorded Call - Last Update: 4s    Call Elapsed: 62
[2021-05-19 03:33:20.000822] (info)       - Stopping P25 Recorder Num [0]    TG: [35m     13601[0m    Freq: 7.697188e+08     TDMA: true    Slot: 1
[2021-05-19 03:33:21.431726] (info)   [ISICS-Bradgate]    TG: 13601    Freq: 7.697188e+08    Broadcastify Upload Success - file size: 254579
[2021-05-19 03:33:49.005933] (info)   Currently Active Calls: 0
[2021-05-19 03:33:49.006119] (info)   Recorders:
[2021-05-19 03:33:49.006192] (info)   [ rtl=0 ]
[2021-05-19 03:33:49.006254] (info)   [ D0 ] State: inactive
[2021-05-19 03:33:49.006316] (info)   [ D1 ] State: inactive
[2021-05-19 03:33:49.006377] (info)   [ D2 ] State: inactive
[2021-05-19 03:33:49.006436] (info)   [ D3 ] State: inactive
[2021-05-19 03:37:01.617359] (info)   [ISICS-Harcourt]    TG: [35m     61910[0m    Freq: 7.699438e+08    TG not in Talkgroup File
[2021-05-19 03:37:01.617537] (info)       - Starting P25 Recorder Num [0]    TG: [35m     61910[0m    Freq: 7.699438e+08     TDMA: true    Slot: 1    Mod: true
[2021-05-19 03:37:01.617674] (info)   [ISICS-Harcourt]    TG: [35m     61910[0m    Freq: 7.699438e+08    [32mStarting Recorder on Src: rtl=0[0m
[2021-05-19 03:37:07.373171] (info)        - Message -     TMDA: true     Slot: 0    Call -     TMDA: true    Slot: 1
[2021-05-19 03:37:07.373360] (info)   [ISICS-Harcourt]    TG: [35m     61910[0m    Freq: 7.699438e+08    Update Retuning - New Freq: 7.699438e+08    Elapsed: 6s     Since update: 2s
[2021-05-19 03:37:10.006858] (info)   Currently Active Calls: 1
[2021-05-19 03:37:10.006987] (info)   TG: [35m     61910[0m Freq: 7.699438e+08 Elapsed: 9 State: recording
[2021-05-19 03:37:10.007102] (info)       [ 0 ] State: active
[2021-05-19 03:37:10.007141] (info)   Recorders:
[2021-05-19 03:37:10.007177] (info)   [ rtl=0 ]
[2021-05-19 03:37:10.007213] (info)   [ D0 ] State: active
[2021-05-19 03:37:10.007249] (info)   [ D1 ] State: inactive
[2021-05-19 03:37:10.007285] (info)   [ D2 ] State: inactive
[2021-05-19 03:37:10.007320] (info)   [ D3 ] State: inactive
[2021-05-19 03:37:24.001072] (info)   [ISICS-Harcourt]    TG: [35m     61910[0m    Freq: 7.699438e+08    Ending Recorded Call - Last Update: 4s    Call Elapsed: 23
[2021-05-19 03:37:24.001427] (info)       - Stopping P25 Recorder Num [0]    TG: [35m     61910[0m    Freq: 7.699438e+08     TDMA: true    Slot: 0
[2021-05-19 03:37:24.930751] (info)   [ISICS-Harcourt]    TG: 61910    Freq: 7.699438e+08    Broadcastify Upload Success - file size: 76711
[2021-05-19 03:40:31.008971] (info)   Currently Active Calls: 0
[2021-05-19 03:40:31.009093] (info)   Recorders:
[2021-05-19 03:40:31.009135] (info)   [ rtl=0 ]
[2021-05-19 03:40:31.009177] (info)   [ D0 ] State: inactive
[2021-05-19 03:40:31.009220] (info)   [ D1 ] State: inactive
[2021-05-19 03:40:31.009260] (info)   [ D2 ] State: inactive
[2021-05-19 03:40:31.009299] (info)   [ D3 ] State: inactive
[2021-05-19 03:43:52.002552] (info)   Currently Active Calls: 0
[2021-05-19 03:43:52.002677] (info)   Recorders:
[2021-05-19 03:43:52.002721] (info)   [ rtl=0 ]
[2021-05-19 03:43:52.002762] (info)   [ D0 ] State: inactive
[2021-05-19 03:43:52.002804] (info)   [ D1 ] State: inactive
[2021-05-19 03:43:52.002844] (info)   [ D2 ] State: inactive
[2021-05-19 03:43:52.002883] (info)   [ D3 ] State: inactive
[2021-05-19 03:47:13.004378] (info)   Currently Active Calls: 0
[2021-05-19 03:47:13.004521] (info)   Recorders:
[2021-05-19 03:47:13.004565] (info)   [ rtl=0 ]
[2021-05-19 03:47:13.004607] (info)   [ D0 ] State: inactive
[2021-05-19 03:47:13.004649] (info)   [ D1 ] State: inactive
[2021-05-19 03:47:13.004689] (info)   [ D2 ] State: inactive
[2021-05-19 03:47:13.004729] (info)   [ D3 ] State: inactive
[2021-05-19 03:50:34.008036] (info)   Currently Active Calls: 0
[2021-05-19 03:50:34.008163] (info)   Recorders:
[2021-05-19 03:50:34.008206] (info)   [ rtl=0 ]
[2021-05-19 03:50:34.008247] (info)   [ D0 ] State: inactive
[2021-05-19 03:50:34.008289] (info)   [ D1 ] State: inactive
[2021-05-19 03:50:34.008328] (info)   [ D2 ] State: inactive
[2021-05-19 03:50:34.008368] (info)   [ D3 ] State: inactive
[2021-05-19 03:51:58.009385] (error)   [ISICS-Bradgate] Retuning to Control Channel: 7.699688e+08
[2021-05-19 03:51:58.009554] (info)        - System Source 0 - Min Freq: 7.688838e+08 Max Freq: 7.708038e+08
[2021-05-19 03:51:58.009702] (error)   [ISICS-Bradgate]     Control Channel Message Decode Rate: 1/sec, count:  3
[2021-05-19 03:52:01.009284] (error)   [ISICS-Bradgate] Retuning to Control Channel: 7.702188e+08
[2021-05-19 03:52:01.009533] (info)        - System Source 0 - Min Freq: 7.688838e+08 Max Freq: 7.708038e+08
[2021-05-19 03:52:01.009711] (error)   [ISICS-Bradgate]     Control Channel Message Decode Rate: 0/sec, count:  0
[2021-05-19 03:52:04.008674] (error)   [ISICS-Bradgate] Retuning to Control Channel: 7.704688e+08
[2021-05-19 03:52:04.008831] (info)        - System Source 0 - Min Freq: 7.688838e+08 Max Freq: 7.708038e+08
[2021-05-19 03:52:04.008946] (error)   [ISICS-Bradgate]     Control Channel Message Decode Rate: 0/sec, count:  0
[2021-05-19 03:52:07.003679] (error)   [ISICS-Bradgate] Retuning to Control Channel: 7.699688e+08
[2021-05-19 03:52:07.003825] (info)        - System Source 0 - Min Freq: 7.688838e+08 Max Freq: 7.708038e+08
[2021-05-19 03:52:07.003934] (error)   [ISICS-Bradgate]     Control Channel Message Decode Rate: 0/sec, count:  0
[2021-05-19 03:52:10.007013] (error)   [ISICS-Bradgate] Retuning to Control Channel: 7.702188e+08
[2021-05-19 03:52:10.007203] (info)        - System Source 0 - Min Freq: 7.688838e+08 Max Freq: 7.708038e+08
[2021-05-19 03:52:10.007358] (error)   [ISICS-Bradgate]     Control Channel Message Decode Rate: 0/sec, count:  0
[2021-05-19 03:52:13.001195] (error)   [ISICS-Bradgate] Retuning to Control Channel: 7.704688e+08
[2021-05-19 03:52:13.001362] (info)        - System Source 0 - Min Freq: 7.688838e+08 Max Freq: 7.708038e+08
[2021-05-19 03:52:13.001466] (error)   [ISICS-Bradgate]     Control Channel Message Decode Rate: 0/sec, count:  0
[2021-05-19 03:52:16.002449] (error)   [ISICS-Bradgate] Retuning to Control Channel: 7.699688e+08
[2021-05-19 03:52:16.002632] (info)        - System Source 0 - Min Freq: 7.688838e+08 Max Freq: 7.708038e+08
[2021-05-19 03:52:16.002785] (error)   [ISICS-Bradgate]     Control Channel Message Decode Rate: 0/sec, count:  0
Code:
    "ver": 2,
    "sources": [{
        "center": 769843750.0,
        "rate": 2048000,
        "ppm": 0,
        "gain": 25,
        "digitalRecorders": 4,
        "driver": "osmosdr",
        "device": "rtl=0"
    "systems": [{
        "modulation": "qpsk",
        "digitalLevels": 3,
        "control_channels": [770443750],
        "type": "p25",
        "shortName": "ISICS-Harcourt",
        "broadcastifyApiKey": "retracted",
        "broadcastifySystemId": "retracted",
        "audioArchive": false
        "digitalLevels": 3,
        "control_channels": [770468750],
        "type": "p25",
        "shortName": "ISICS-Bradgate",
    "broadcastifyCallsServer": "https://api.broadcastify.com/call-upload",
    "controlWarnRate": 5,
    "callTimeout": 0.75
