TRX-1 Loading P25
SLScanner
Salt Lake City
Our State or at least Salt Lake County and ajoring towns just switch to P-25 I have a TRX-1 scanner for years with all the FM channels that worked good.
I have two sons that are Paramedics that I need to listen to but have no idea how to up load any of the new p-25 talkgroups could some body tell me where to start and tell me if we can use Radio Reference to up load them?
Clyde
SLScanner
Salt Lake City
I was hopping some one could refer me to a u tube clip. I am a 75 year old man not to smart when it comes to all this.
Do I need to delete my software and re install a new one. Could someone help me with this that is a little more down to earth and I can Mable understand.
First of all, you do NOT need to delete your software, please DO NOT do that. That said...
I'm sure there are YouTube videos out there but I do not know of any. What exactly are you trying to do, I'm a little confused by the wording of the posts, are you trying to add the new P25 system or is it loaded and you just want to add talkgroups?
Either way it is not difficult and once I know what you need to do I'll try to make you a cheat-sheet with screenshots to help.
tvengr
Well Known Member
Baltimore County, MD
Would you know if these are the talkgroups you need?
55922fTSLC FD 1Salt Lake City Fire 1Fire Dispatch
561231TSLC FD 3 PagerSalt Lake City Fire 3/PagingFire Dispatch
2923b6bTVECC EMS 1VECC EMS 1/PagingEMS-Talk
2924b6cTVECC EMS 2VECC EMS 2EMS-Talk
2925b6dTVECC EMS 3VECC EMS 3EMS-Talk
2926b6eTVECC EMS 4VECC EMS 4EMS-Talk
2929b71TVECC EMS 5VECC EMS 5EMS-Talk
Please keep in mind, the new Salt Lake/Statewide system is simulcast and depending where you are in relationship to the towers you may get good to no reception as the TRX-1 isn't designed to receive simulcast signals.
Whiskey3JMC
Quiet numbskulls I'm broadcasting!
Simulcastylvania, TE
Zip scanners has a series of YouTube tutorial videos. Assuming your sons' agency(ies) is (are) listed in the RRDB then you'll want to do a library import via their programming app. Everything is summarized in this video. If you're seeking assistance regarding what agency operates where then that/those question(s) would be better addressed in the Utah Discussion Forum
Best wishes!
SLScanner
Salt Lake City
Yes all of them mostly the VECC those are Unified Fire
Everything right now my scanner is just set up for FM channels on the trunking system. I need to install a p-25 system from the start
See if this document helps you, the frequencies used as an example are the correct ones for your tower/site. If you run into any issues feel free to mention me here or DM.
  • Add System WS_TRX.pdf
tvengr
Well Known Member
If you attach your configuration file, I can add the P25 system to what is already in your scanner. Click on Attach files and open the file.
SLScanner
Salt Lake City
I belive I have set everything right but my scanner will not change from Mot to p25 on the select type screen when I try to save it nothing . so when I up load what I have I believe is right the scanner says there is nothing to scan. any odeas why it won't change
Thanks Clyde
Thanks Clyde
I would delete that system and start over, the FIRST thing you should do after clicking on new is change it to P25. It is possible once you add information it won't let you go back and make changes to system type.
SLScanner
Salt Lake City
Got everything working, just can't change the scanner from MOT to P25 it will act like it does but will not save so I am no reciving anything . But the scanner is working as it should other that that I think
thanks
SLScanner
Salt Lake City
Started to hear garbble sounds but nothings you can understand and very few and far between. Any ideas where to go from here .
thanks
Post #14 above. You have to start over and create this as a P25 system.
See post #14
SLScanner
Salt Lake City
Well I have tried to reset to a new system all morning to no availed. Started fresh a number of times first thing was I set the type to p25 but it would not save I must still be doing something very wrong I thing I JUST GOT A NEW PAPER WEIGHT!
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
Your use of the word “reset” makes it sound like you are trying to change the existing system to P25. You need to ignore what you have and create a new one. First thing it should ask is system type.
