TRX-2: TRX 2 Eorror message
LB_Scan
Hi
After I download the EZ Scan software I get this message 00930237 in module address 0000000008
LB_Scan
Hi @Whiskey3JMC
I did run it in administrator then it work then i run in the other login i get that message. thanks
LB_Scan
Hi
How come ez scan program work in the administrator and not the other login profile. thanks
LB_Scan
Hi
So far i did a clean install on ez scan program. Going on admin profile same message. This link dose not work this thread. Maybe if ez scan had a new version of the program maybe it will work. thanks
Whiskey3JMC
Simulcastylvania, TE
Works fine for me (thread is closed so you can't reply but you should be able to view)
