I just purchased a TRX-2 and got it programmed, after programming I found out that it isn't receiving DMR. can someone please help me
What exactly are you trying to monitor? Where are you trying to monitor? How did you program it? Have you updated it to the latest firmware? Did you update the RRDB in the software?
Did you add all the talk-groups? If not known? just add a WILDCARD in the EZSCAN Trunked settings where the talk-groups would be listed. That's what I had to do for a School District DMR here with my WS1080. I found 3 new talk-groups that way. OR you might try adding the frequencies as conventional objects only, not as a trunked system. Then set the delay to 5 or 6 seconds. I also dropped back to the 4.1 firmware as 4.3 ruined my ability to listen to DMR trunked systems. Don't know why but I'm sure it's debated on a forum post somewhere. 4.1 works perfect.
I just updated the firmware to 3.3 and the Oceana Police Private is working now. I guess I'll have to wait until Monday to see if the board of education channels will work now. It is to my knowledge that the board of education channels are set up as conventional DMR channels and not trunking.
@102Whisenant- Yes. School hour monitoring worked for me.
@mikeS104 - Yes, I went between 4.3 and 4.1 about 8 times comparing the two. 4.3 ruins stuff. We discussed this in another thread after other's noticed they could no longer get two sided conversations on their trunked DMR systems. My videos on Youtube were both for a DMR site using 4.1. They were nothing like that after after 4.3 came out. I just went to Whistler and got the app for dropping back to 4.1 and I'm listening to it now perfectly. Also a specialized yagi antenna for the correct frequencies made all the difference. Even with that antenna, 4.3 doesn't trunk right. 4.1 it is.
I don't see DMR listed for the BOE but it may not be up to date.
Raleigh County, West Virginia (WV) Scanner Frequencies and Radio Frequency Reference
