TRX-2 Trunking frequency lists
ab5r
After programming a Trunked System into EZScan, is it normal for just the Control Frequencies to be listed, and not the voice frequencies?
Having difficulty receiving some P25 freqs. and not others believed to be in the clear and not encrypted!
Usually the control and alternates, but just control should work for majority of systems.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
You can choose in the import options whether or not you import all frequencies or just the ones listed as control channels (assuming you are referencing a library import).
ab5r
Thank you Glenn and Kevin. I was just double checking. There is SOOOOOOO much to be desired in the EZScan documentation!!!
